Turbo Question
Old May 4, 2009 | 11:49 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Default Turbo Question
Ok to run without a down pipe/wastegate pipe attached??? I'm troubleshooting my vibrations and it's a pain to work around the APS kit. I've taken the down pipes/wastegate pipes off the car, and was planning on doing a short run with some idle revs to check for a vibration, nothing more. Is this going to cause any problems or issues by running with the backsides of the turbo's open like that?
Old May 5, 2009 | 12:34 AM
TheDingo's Avatar
TheDingo
the wastegate is on the downpipe?
I'd say you could leave them open coming out the back but I'd put the wastegate on.
Old May 5, 2009 | 12:54 AM
marky_24's Avatar
marky_24
i would guess you would be ok if you stayed out of boost. you dont want 1200+ degree exhaust melting everything behind the turbos.
Old May 5, 2009 | 09:57 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
Yes, the APS kit has a separate pipe siamesed with the down pipe for the wastegates.
This is only going to be about a 30 second run. Start it, let it catch idle, throw a couple of revs to 2000-2500 RPM, kill it. Just checking for the cyclical vibration I'm chasing down.
Old May 5, 2009 | 10:00 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
You'll be fine as long as you don't try loading up the car while on the throttle and you address any possible issues from the heat.
Old May 5, 2009 | 11:14 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
The exhaust will be hitting the waffle styled aluminum heat shielding. SHould be ok. Just a PITA to redrop the manifolds to put the DP's back on to test run for 30 seconds before pulling it all apart again.
Good news is at least I dind't have to undo any of the oil/coolant feed lines to do this.
Old May 5, 2009 | 11:18 AM
Rkreigh's Avatar
Rkreigh
it will be fine, you can always clamp a clothes dryer pipe on there if you want to divert the exh. unless you are dynoing the car, no worries
exh does get pretty hot under load!!
Old May 5, 2009 | 01:01 PM
Slow Z06's Avatar
Slow Z06
without wastegates how do you plan on regulating the boost?
Old May 5, 2009 | 01:42 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
Because the tubes that divert to the wastegates are wide open, so in theory it shouldn't make any boost at all. Besides, I'm not looking to load up the motor, just start it and throw a couple of revs at it to see if the vibration is still present as I remove items one at a time.
To Turbo Question
