additional maintenance?
May 10, 2009 | 07:53 AM
Hello,I usually don't post much in this section but I have been looking at a Procharger setup recently so it has sparked some questions in my mind. Most importantly,what kind of effect will adding a supercharger have on my routine maintenance?
May 10, 2009 | 08:15 AM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
None really!
I just changed my oil at the regular time as usual.
Plugs need to be the NGK TR6's and those will be fine too. They really ar e bolt on performance pieces and kick some serious butt!
Thanks,Matt
May 10, 2009 | 09:46 AM
I change my tires along with my oil now if that's what you're asking.
May 10, 2009 | 01:01 PM
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Quote:
Originally Posted by
BLOWNBLUEZ06
Ya beat me to it.
May 10, 2009 | 01:14 PM
Depending on which Bracket/Tensioner assembly you get, you could also be changing belts pretty regular.
Do your research before buying a kit.
May 10, 2009 | 01:45 PM
JET LEE
Is there a kit you would recommend? I was looking at one in the used parts section.
May 10, 2009 | 02:00 PM
May 10, 2009 | 02:20 PM
Lancejoker
procharger D1 you cant go wrong...its ben proovem on the track and street.!!!!!!!!!!!!!!!!!!!!!!
May 10, 2009 | 02:54 PM
my headunit is self contained so i change the oil in the supercharger when i change my engine oil
May 10, 2009 | 03:05 PM
slothy
a&a or ecs
