APS guys
Old May 12, 2009 | 09:48 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default APS guys
Hey guys,
I bought the kit used (In GREAT shape) and the instructions call for studs to hold the exhaust manifolds to the heads. I didnt get these with my kit but is it ok to use my bolts or does it NEED studs ?
Old May 12, 2009 | 09:53 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Originally Posted by Corvette-Chris
Hey guys,
I would recommend some good high grade studs. You want full thread purchase into the cylinder heads with the added weight. Not a place you want to cut corners and it's not too inexpensive to even consider cutting that corner. Call Will and tell him to send them to you as they're part of the kit.
Old May 12, 2009 | 10:05 PM
Corvette-Chris
St. Jude Donor '08
Will do...As always, thanks Bret
Old May 13, 2009 | 08:49 AM
Slow Z06's Avatar
Slow Z06
Hurry UP!!!!!! Looking forward to the results.
Tunning mine now. 10# is nuts!!!!
Old May 13, 2009 | 08:57 AM
Corvette-Chris
St. Jude Donor '08
Im trying bro! lol
Sent the manifolds to Dallas to get ceramic coated but should have them by weeks end. Im jumping around on the instructions making cuts here and there.
Got the meth kit mounted and wired.
More tinkering continues today LOL
Old May 13, 2009 | 09:09 AM
Slow Z06's Avatar
Slow Z06
SWEET!!!!!!
You going to tune it or send it out to be done?
Old May 13, 2009 | 09:14 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
If you do go with the studs, be prepared to become a contortionist when you put the manifold in. The passenger side manifold will go on with the front four studs in place, but the drivers side manifold will NOT go in place with any in. I was fighting this for a couple of hours last night before giving up. I believe what you're going to have to do is hold the manifold up and start a couple then fights to get the rest of the holes lined up. There simply isn't the clearance on the drivers side.
I have the APR stainless studs, and I will forewarn you, the little tiny allen keys they are sized for like to strip out pretty quick. If this happens, use a second 6pt nut and jamb it and an ARP nut together and tighten the studs down using the jambed nuts.
Old May 13, 2009 | 09:18 AM
Corvette-Chris
St. Jude Donor '08
Cool, thanks for the heads up.
So I dont have to wait on studs from APS, I can simply use header studs from ARP and they are the same length, etc...?
Old May 13, 2009 | 09:45 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
Yup. The flange on the APS kit is no thicker than your normal headers IIRC. A standard set of ARP studs will do fine.
Recommendation if you haven't gotten this far: Replace your turbo to downpipe studs with some stainless hardware. When I removed my downpipes last week, I had about half of the nuts come off, and the other half took the studs out of the back of the turbo. The supplied hardware with the APS kit isn't meant for multiple cycling.
Also, VERY closely inspect your oil drain hoses (the rubber ones). Look at the following thread, it's got pics and measurements for new hoses. http://forums.corvetteforum.com/c5-f...oil-lines.html
Last, be very wary of the APS supplied scavenge pump. Mine took a crap at 4K miles (two years on car) and pushed oil through both turbos, crapping the seals out on the drivers side it looks like. I replaced my APS pump with a TurboWerx EXA pump and am not looking back.
Old May 13, 2009 | 10:17 AM
Corvette-Chris
St. Jude Donor '08
SWEET!!!!!!
Taylor @ Dallas Performance tunes it.
Yeah I took my downpipes off the other day and the same thing happened to me. IIRC, this kit has very low milage on it, and it shows bc it is in great shape. Ill keep an eye on the scavenge pump.
To APS guys
