so i just installed a plate kit on my 04 zo6,new silonoids ,new window switch..i have it programed to come on at 3000 rpm,and when it does it boggs out for a split second then hits really hard . im asking what would make it bog befor it hits? thanks in advance
how much are you spraying? Timing retard? Other saftey features such as a lean disarm switch? Tuned? Bottle pressure? why no purge? Wet - dry? If wet what pills? A/F guage??
spraying a 150,dont know about timing as ,no lean switch,tuned yes,bottle pressure consistant 1000psi purge,yes . wet kit 38 fuel and 52 n2o, a/f guage no
did they spray it when they tuned it or just tune it and say it was good? Honestly you need a wideband to know what your AFR is so as to correctly adjust it if need be.
The long lines wont matter, i would purge before you spray however.
Whether or not the plugs are new makes no diference if it melted an electrode ( been there done that )
i can tell you this, with that jetting you are way too fat. dave's plate is 65n 38f at 55psi for a 150 shot. that is also on the conservative side. im running a 65n 35f at 50psi with 23 degrees of total timing and am still a **** hair fat, but every car is different. you need to find out what your total timing is, get a wideband, and pull a plug. what plugs are you running?
it is one of daves kits from nitrous outlet and im pretty sure i followed the chart that came with the pills with out haveing it in front of me i might be alittle off with the #s but that is another thing i am running stock fuel pump so it would help if i got a boost a pump? oh and 42lb injectors
yes they spayed it when they tuned it and it stumbled on the dyno but said it was just clearing the lines
a boost a pump with a racetronix harness will help, but without knowing what your timing is, reading the plugs, and knowing wha the af is your pissing in the wind. what plugs are in the car?
ngk tr6 and i know my tuner is getting back to me with more info
