Ok so I have L92 heads with dual springs...I have had them on for 2 years with no issue. I went out the other day and was beating on the car a little and it was running fine and actually still is, but the car has a hellatious tick/tap to it now. So far I have done a compression test with all results being within 3% of each other. I have removed rocker arms and checked all of the needle bearings. I have checked all pushrods, and removed both inner and outer valve springs completely and inspected them. Anybody got anything else they can recommend before I yank the head?
Honestly it doesn't sound like a lifter. It sounds almost like something right under the valve cover. I can't really say for sure, but I guess I am just going to have to pull the heads to check.
Check your header bolts...I let mine get loose once and I swore I had a lifter going south. Exhaust leak out of the header gasket. hahaha Hope it's that simple for you.
Which bank is the noise on ?
I would try to isolate which cylinder it is by removing the valve cover and having someone tap the key once or twice. Pull the fuse for the fuel pump.
You could yank the pushrods out of 1 cylinder at a time and run the engine. The lifters will get suspended in the retainers and if the noise goes away, you know what cylinder it is. That's what the Great Taylor from Dallas Performance would do.
