Help with CAM Selection
Jun 2, 2009 | 09:14 AM
St. Jude Contributor
Hi guys, as the title states. I'm putting together a forged 416 LS3 stroker with a Novi 2000 blower, and 8 rib setup, I've decided on AFR 225cc Heads. Now I need some help selecting the proper cam. My goal is to have a stealth cam of some sort. I don't want a lumpy cam or rough idol. Suggestion?
Jun 2, 2009 | 09:54 AM
Andy offers a selection of cams and IMHO his "stage 4" or even "stage 5" would deliver smooth driveability while not being swallowed up by your 416cid. You will want to maximize the potential of the coveted AFR 225's in your 416cid. In addition, I am pretty sure that ECS & EPP also design & sell blower cams for the larger cubed applications as well.
A&A Corvette Performance stage 4 blower camshaft.
Hydraulic Roller
Duration @ 0.050" Intake Exhaust 220 234
Valve Lift: Intake Exhaust .581 .598
Lobe Seperation Angle 117°
A&A Corvette Performance stage 5 blower camshaft.
Hydraulic Roller
Duration @ 0.050" Intake Exhaust 224 238
Valve Lift Intake Exhaust .581 .605
Lobe Seperation Angle 115°
Reason: typo
Jun 2, 2009 | 11:03 AM
Stage 4 A&A cam in my 403. I am quite happy with it. Idles and drives like stock until the pedal gets mashed.
Jun 2, 2009 | 11:58 AM
Quote:
Originally Posted by
BLOWNBLUEZ06
Get back to work Bret
Jun 2, 2009 | 01:01 PM
NemesisC5
Jun 2, 2009 | 04:22 PM
BLOWNBLUEZ06
I stopped by my house to get something & couldn't resist checking the forum
Jun 2, 2009 | 05:06 PM
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Feel free to call the shop, we have a great cam that will fit your exact needs.
Jun 2, 2009 | 05:50 PM
St. Jude Donor '08
I see that your in MI....why not contact Dr. Phil and see what he suggest?
Jun 2, 2009 | 06:55 PM
Corvette-Chris
Phil knows all about this package, he is the one that's doing all the work. I'd like to get some direction initially.
Jun 2, 2009 | 07:38 PM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Sponge Vette
Why not go with Dr. Phil's custom grind cam? He is all about/for stealth
Jun 2, 2009 | 07:42 PM
If it's already at Dr. Phil's, just tell him what you want and he'll get it done!
Some people order cams from him specifically for their custom setup. You're in great hands!
Jun 2, 2009 | 08:04 PM
St. Jude Donor '06 & '12
232/240 .60x/.610 115+2 or 116+x
That is an AWESOME blower cam for your setup. The 416 will swallow the cam up, and have that baby running like stock. Combine that with an LSA of 115-116, you'll be set.
Were a W/D with Comp, so we can have any cam you want cut for 399.00
Jun 3, 2009 | 08:34 PM
Jeff @ TPE
That's a great cam
