Cam Only?
Old Jun 2, 2009 | 12:55 PM
TheBigDog's Avatar
TheBigDog
Default Cam Only?
If I install a good turbo cam only without the heads how much HP gain can I expect? Do I need to install heads? I have the TTi X kit in my car and with the kit only and a really safe tune I got 471 HP on the dyno. I could have gotten more, but didn't want to granade the engine.
Thanks,
The Big Dog
Old Jun 2, 2009 | 01:00 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Dunno how much more power you will make. With the right choice, I wouldn't be surprised to see it make another 50rwhp. It should spool the turbos faster too.
Old Jun 2, 2009 | 01:26 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
and if you throw a AlkyControl Methanol Injection Kit on it you could easily see another 30 RWHP and it'll keep the safety factor way low!
So safely with the Cam and Meth you coulld see an 80 RWHP increase (I would not be suprised that there is much more in your Vette right now the way it sits)
How much B@@ST did you have on the Dyno, do you have the sheet you could post?
Thanks,Matt
Old Jun 2, 2009 | 02:45 PM
TheBigDog's Avatar
TheBigDog
Thanks,Matt
Matt,
I have a meth kit installed and tuned without. I believe the tech told me it was at 8.5 lbs of boost.
Thanks,
The Big Dog
Old Jun 2, 2009 | 02:47 PM
TheBigDog's Avatar
TheBigDog
How does the cam spool turbos up quicker ?
Thanks,
The Big Dog
Old Jun 3, 2009 | 01:51 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
It will easily make another 50rwhp. A probably designed cam will do wonders for a turbo car.
To Cam Only?
