when i lost my belt of coarse the motor started to run warm so i shut it down i thought it was to soppesed to shut down 4 cyl so u could make it home it did not seam to do so does it haft to be turned on or does it activete on its owen thanks jon
When you lose the belt your water pump is not spinning any more. So you are not moving coolant through the block. 8 cyl, 4 cyl, 1 cyl, without any coolant flow it’s going to over heat.
The big issue is why did you loose the belt?
You may want to look into a product that we offer that helps eliminate belt slip and also reduces the chances of loosing a belt greatly. Check out the below link.
thanks i will it came off because of the alt bolt backing off cocked the pullly and away it went left me on the side of 95 till 230 in the morning hadr to find some one to tow a vette
Sorry for your misfortune…being left on the side of the road at 2:30AM can be aggravating.
Serpentine belt systems that are used to spin a super charger tend to put a lot of stress on the accessories.
Another benefit of our kit is that it eliminates the excessive stress on all accessories while increasing the life span of the accessories in a super charged environment.
You might want to seriously think about the FLIP-DRIVE set-up!
I have it in conjunction with my Electric Water Pump(EWP) so if that belt throws at least I still have the water pump going - but if you should ever throw a Blower belt with the Flip-Drive you wont have any problems
