Finally getting around to putting my tt car back together.
Is it necessary to dial in the bell housing (quicktime) before putting everything back together?
the object is to align the driveshaft (torque tube in this case) even with the crankshaft to prevent premature ware on the throw out bearing and viberations, etc. Im thinking the two opposite dowl pins force the alignment to be proper but it never hurts to ask
I'd like to cut an inch off the bottom that sticks out. Got a speedbump in my neighborhood that hits if I go too fast, and rocks your marbles hitting there!
