Need Carb # from Vortech S Trim :)
Hey guys
I am going to stamp a carb # onto my YSi so I need to have a valid carb# from an S Trim.
If you have a Vortech S Trim supercharger the number is right on the top. They are all the same on every S Trim.
thanks !
thanks !
There should be a plate with light Blue trim on it. There is a slot for the Carb# on that plate. It should be visible on the upper passengers side of the blower.
Right on!
Unfortunately I have the ProCharger or I'd forward the # to you!
Thanks,Matt
Thanks,Matt
USMC (retired)
When I had my car smogged earlier this year they called in the carb EO# to the state off my T-Trim head unit and made sure it was correct for my year/model vehicle. There are many different EO#'s for at least the T-Trims out there so maybe S-Trims have different numbers as well for different applications/models?
