Supercharged Heat Problems Try This Mod
Old Jul 1, 2009 | 08:01 AM
BobJ's Avatar
BobJ
Originally Posted by Tom DeWitt
You are not the first one to say the radiator did nothing. Most of the time it's because changing the radiator is only upgrading the cars ability to cool more. These new cars are "told" what temperature to run at by the ecm, thermostat, and fan controls. Unless you make other changes, as you did with air flow, nothing will happen. It's kind of like doubling the size of your furnace or AC in the house and setting the temperature at 70 degrees. You'll still get 70 degrees, but if you ask for 55 you might actually get there. It's all about capacity.
Hey Tom,
For the record, you make a great product and I don't "regret" getting one for my car AT ALL. I did notice that the "average" running temp is lower by about 20 degrees, so if someone tracks their car I think this is where your products would come into play (and that's what they're made for!)
As you mention it just didn't resolve my problem which was lack of air flow to the rad (any rad). Forum members tried to tell me flow was the problem but my rad was the original, car was 10-years old, I live in AZ....it seemed like a reasonable thing to do. I had reporgrammed the fans, tested them, had a 160 T-stat, etc. (readers, these are good, inexpensive steps as well).
I hope you didn't feel I was unhappy with your product, or was talking it down becuase that was not my intent. You and Ron Davis are the two leaders in the industry in my opinion, Davis is right here in my backyard and I chose your product over his, I felt it was a much better value.
Cheers....
Old Jul 1, 2009 | 10:05 AM
hattitude's Avatar
hattitude
Originally Posted by BobJ
I have some pics at work, I'll post them tomorrow. It was fairly straight forward;
1) Remove the front bumper cover.
2) Remove heat exchanger
3) Remove or "shave" foam behind bumper cover to accomodate heat exchanger.
4) Brackets that come with KB heat exchanger can be used to mount it in new position. You have to flip/rotate them, it will make sense when you're looking at it.
5) Cut some hose for the new length, or get pre-molded hoses as required.
6) You'll want to do ONE BMF's front license plate mod to adequate air flow to the heat exhanger. I also removed the fog light housings to increase air flow (you don't need them).
7) Say goodbye to high coolant temps!!
Can't wait to see these pics........
Old Jul 1, 2009 | 12:01 PM
reneeautumn's Avatar
reneeautumn
yup, same prob in ny
Old Jul 1, 2009 | 12:05 PM
reneeautumn
heat issues solved for me...dewits rad, open up fog bezels, "spal fans" from dewit, B&M maxi cooler wfans(2) that's about it and oh, 180 deg stat...from ny, so front plate required.
Old Jul 2, 2009 | 08:50 AM
71'AirStrike's Avatar
71'AirStrike
He was my solution to my severe overheating of my F/I 402.
As is I would get 230* eng temps at calm highway speeds and when I hit stop and go traffic it would climb to 260* real fast.
So I did a lot of research (thanks CF!) and did the following
A: ensured a 100% seal from the fans to the radiator
B: reworked the radiator shroud so it only sucked air from the bottom just like OEM.
C: made sure the lower Air dam was in place with the most room given to the radiator.
This is what I had to work with. A A and A FMIC, on a tiger shark nose
So I bought a junkyard OEM shroud and started test fitting.
Once I got the shape I wanted, time to use 5 min epoxy to set her in.
Woah thats ugly…. but it works! I used Kentucky chrome (aluminum foil tape) to seal up the radiator and rubber foam to seal up the front shroud.
Those ugly angle metal bits serve 2 parts. One they hold the shroud in place, and two they “pull” on the shroud to wrap around the Output part of the FMIC.
As you can see here I have some circular cut foam to make that output FMIC sealed up.
I had to tweak the air dam to get it at 100% OEM-ish fashion.
To complete the testing I drove around like a redneck with my hood off. Yee Haw!
cheers
cahd
Old Jul 2, 2009 | 12:15 PM
Warp Factor's Avatar
Warp Factor
I made a few small changes to BMFs mod, in case anyone wants to incorporate them:
First, I made the cutout in the bumper cover smaller, leaving the license plate attachment points, so if anyone ever needs to put on a front plate, they won't need to purchase a new front bumper.
Second, I used a drum sander to get a super neat trim on the front piece, so that rubber molding doesn't need to be used to clean it up. It looks quite good this way.
Third, the original hot-melt adhesive started to let go after a hot drive (or maybe it was parking after the hot drive). Or maybe it had nothing to do with the heat.
To glue the second time, I roughed up the plastic gluing surface with sandpaper; put down a bead of silicone adhesive; pushed the screen into the bead so it oozed through; put another bead on top to join to what had oozed through.
A lot of other adhesives will do, but the silicone was handy, is pretty tough stuff, stays where you put it (doesn't run), and I thought it would be good to use something flexible and heat resistant.
Old Jul 2, 2009 | 01:39 PM
hawkeyeintx's Avatar
hawkeyeintx
Sounds nice. Got any pics you can post?
Old Jul 2, 2009 | 07:04 PM
Warp Factor
Here's one. The area behind the screen can be trimmed back much farther, and still hold a license plate if necessary. I kept cutting more away and flexing to see if the area was still strong. When I got to this point, I thought, "Hmm, that looks kind of interesting" so I stopped.
If I'd thought of it, maybe I would have made the opening in the shape of the Chevy Bow Tie.
