How hot does an Intercooler get?
Im wondering how hot the FMIC gets?
What im trouble shooting is the outsie air (not the chrged air that feeds the engine) that passes through the FMIC.
Im working on an engine cooling issue and im wondering if the FMIC is 'front loading' the outside air before it hits the radatior.
thank you
cheers
chad
The way around the problem, is to do a couple of things.
1) Create a wedge between the I/C and radiator at the bottom
2) Modify your radiator with a lower scoop to help direct the air through the I/C
3) Install a larger aftermarket radiator
4) Cut open the license plate shroud
Unfortunately, FMIC's in the western heat hurt more than help. But with the right modifications, you can at least make it manageable.
I wouldnt worry about how hot the I/C is getting. That is not your problem.
Let us know if we can help at all. We've spent the last 4 years focusing quite heavily on S/C and engine cooling.
thank you
cheers
chad
