Boosted 398 w/ SD tune throwing codes:
Old Jun 27, 2009 | 11:03 PM
95redz's Avatar
95redz
Default Boosted 398 w/ SD tune throwing codes:
Hi all,
I recently bought a forged up 398 with a D1sc with an SD tune using EFI live. Ive had it for 60 days now and its never once thrown codes. Last night is starting spewing a check engine light:
I pulled these codes:
99 HVAC B0361 H C = B0361 Left Actuator Feedback Short to GND
10 PCM P0102 H C = P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
10 PCM P0418 H C = P0418 AIR Pump Relay Control Circuit
10 PCM P0441 H C = P0441 EVAP System No Flow During Purge
Any reason these codes are coming up now??
Edit* here is the car with all the mods: http://forums.corvetteforum.com/c5-c...03-eb-z06.html
Old Jun 27, 2009 | 11:40 PM
AlwaysInBoost's Avatar
AlwaysInBoost
how is it running? any logs?
you should try posting your question on the forums here www.efilive.com
Old Jul 2, 2009 | 10:53 PM
95redz's Avatar
95redz
No logs since I dont have any software at the moment. Car runs fine except for the tables beeing a bit off for this elevation. The last serious tune it got was in Colorado, Its now in Northern Canada. It runs a bit lean down low and sometimes stumbles but thats just the tune. Its also in need of a new fuel system since it runs out of PSI up top, but that shouldnt throw codes.
We havn't touched the tune at all since I bought it 3200 kms ago, and now I have phantom codes?? weird. For sale?? lol
Old Jul 2, 2009 | 10:56 PM
exploder's Avatar
exploder
the sd tune is always going to have a p0102, the rest of the codes can just be turned off.
Old Jul 2, 2009 | 11:17 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Originally Posted by 95redz
Hi all,
Except for the HVAC which is your A/C all of those should be tuned out.
Old Jul 2, 2009 | 11:24 PM
95redz's Avatar
95redz
So maybe the HVAC code light up the SES then and now its showing the other codes as current?? The light coming on makes no sense as NOTHING has been changed since I bought this car and it wasn't throwing codes then....weird.
To Boosted 398 w/ SD tune throwing codes:
