a%a new bracket install
Old Jul 8, 2009 | 11:39 AM
JAMESNORTHPROV's Avatar
JAMESNORTHPROV
Default a%a new bracket install
guys, just need a quick idear on the best way to install the new bracket, do i mount it already hung on the bracket with the belt on. have not done one before so need a little help. i would call andy but i am on the east coast and its to early. thanks jim
Old Jul 8, 2009 | 12:09 PM
Brian@FI Performance's Avatar
0Brian@FI Performance
Former Vendor
From: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
James,
What I do is on A&A Triple is the following:
Have your SC back plate mounted to the engine
Pull the alternator top bolt and allow the alt. to slide and rest on the bracket, this gives you some room to work the belt.
Bring the belt up on the SC side and make your belt run around your idlers and SC pulley while making sure it doesn't get caught on the back side of the tensioner and block.
Get underneath and make sure the belt is going around the crank properly.
Now loosely bolt up the front side of the bracket to the back.
Make your belt run on the accessory side, alt. ps pump, w.pump etc....
Now what I do here is work the belt over the alt. pulley. I use a bit of lithium (no flames please, it works with no bad result) to help slide the belt over. I put just a bit where the blet is going to slide over the pulley. Once the belt is over the alt. pulley and rest of the belt is looped correctly tighten up all SC bracket bolts.
Use a pry bar to move the alt. back into place, re-install alt. top bolt and you should be good to go.
If you need any FI Accessories, let me know, that is my specialty.
Brian
Old Jul 8, 2009 | 04:44 PM
JAMESNORTHPROV
Default a&A BRACKET
THANKS BRIAN , LET YOU KNOW HOW IT WORKS OUT. JIM
Old Jul 8, 2009 | 07:10 PM
tail_lights's Avatar
tail_lights
Old Jul 9, 2009 | 10:38 AM
Former Vendor
No problem guys!! Like I said, the biggest PITA is around the tensioner/crank area, it is super tight. That is why lately I have been bring the belt up from the bottom so I can twist the belt vertical and get it to slide through the gap.
Brian
To a%a new bracket install
