Meth tank
Old Jul 17, 2009 | 12:37 AM
denscor's Avatar
denscor
Default Meth tank
When you use your window washer tank, do you still have your washer pump hooked up? Or is it just there to plug the hole? Also If you do not use it could a fitting be used were the hole was ( drilling it out to make it accept a bulk head fitting)?
Old Jul 17, 2009 | 08:04 AM
clif's Avatar
clif
St. Jude Donor '09-'10
When I bought my Alky Controls meth kit, it came with a plug to go in the hole for the washer pump.
I miss my washers, so I am looking for a different tank.
Old Jul 17, 2009 | 10:02 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
The kit comes with all you need to install it! Rubber plugs and gaskets for a complete install.
You will actually disconnect your pump and put it away somewhere and then route all you hoses as per the instructions
It is pretty staright forward and comes out real clean and nice, my buddy bought a remote tank to use for his washer fluid, it came with a neck and it fits for our Vettes and the pump pops right in. I have my pump re-moved and the wire harness taped off and secured off to the side
Get your kit here http://www.alkycontrol.com/
Thanks,Matt
Old Jul 17, 2009 | 11:47 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
I left mine hooked up, however I have a wiper delete Vette
Old Jul 17, 2009 | 09:56 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
left mine hooked up as well
Old Jul 18, 2009 | 02:37 PM
corvettebob1's Avatar
corvettebob1
At first I left mine hooked up also, then I found it leaked meth out the wipers all over the cowl under hard acceleration.
So I pulled the line off and plugged the pump.
Old Jul 18, 2009 | 11:03 PM
denscor's Avatar
denscor
What type of plug is used for the washer pump motor hole? I have the Snow kit. Also were is a good place to put the jets at?
Old Jul 19, 2009 | 03:00 PM
corvettebob1
I left the pump in place and just used a plug to seal the outlet of the pump.
Jet's go between the MAF and TB. before the IAT.
To Meth tank
