Corvette-Chris' APS TT C5 - Dyno Results 768 rwhp 690 rwtq
Former Vendor
Chris you had AFR 205's before correct? Those are a 66cc chamber. If you were at 11.0:1 with a 66cc chamber and you now have a 72cc chamber you are at about 10.2:1. 6cc's is usually worth about 8/10ths of a point of CR.
I actually think that the APS and ATI's revised twin ICs could be a better option for Roadcourse setups (like LPE engineered) because they are efficient enough liimit pressure drop and will flow enough CFM to support big time hp. Back when we were all going to single FMIC...the twin IC options were pretty small and really only aimed at around the 600-700rwhp mark.
I think the new twin ICs would be helpful for sustained HPDE as the area immediately in front of the Rad is open using the Twin ICs vs. a FMIC.
Of course AVB tracked the hell (HPDE) out his car and in hot weather 100* temps. From what I could see from his data logging is that his coolant and oil temps were really even with an FMIC..but he had a Tigershark front end as well.
It would be nice to see how much difference (I have to imagine a little) the coolant temps would be with Twin ICs..although it might actually make a bigger difference in stop and go traffic.
I haven't had any issues in Stop and Go traffic..but I could easily switch out my FMIC for Twins if I wanted to try it as my Turbos could route the charge plumbing to Twin ICs pretty easily.
St. Jude Donor '08
^ I kind of like the idea of the twin IC's also so my radiator doesnt get restricted in anyway whatsoever, esp since I drive the car ALL the time in this HOOOTTTT Louisiana weather!
I also run the Tigershark front fascia so that helps airflow even more
#33
St. Jude Donor '08
Thanks Nouman....Its been a long time coming
Not sure to be honest with you...I really dont see myself turning it up past what its on. Ive seen other forged 347 cid motors handle 18 psi so I think my motor would be ok. The transmission and turbos probably wouldnt like it for long periods of time
#39
St. Jude Donor '08
Im sure me and some local guys will get into something LOL
