Corvette-Chris' APS TT C5 - Dyno Results 768 rwhp 690 rwtq
#83
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
Not to bring up such an old thread but I stumbled across this today and I believe I now own this car. It's changed quite a bit after Taylor bought it from u, and then I changed it some more.
Still on the APS kit with some upgrades, it now makes 946whp/899ftlbstrq on e85 @ 18psi.
#84
The previous owner blew up the motor Chris had in it and it's now a 6.0 LS2 block fully built with worked 243's. The turbos were also sent back to FP and upgraded with billet wheels and clipped turbines. That bumped them up to 70lb/min each so the car is capable of a ton of power. The only reason it's where it is now at 18psi is the gate springs being 9lbs and the controller only being able to double the gate pressure.
#85
Pro Mechanic
#86
This gives me hope. I've got a forged 377 LS3 short that previously did around 825-850 with the LG 70LB/min turbos. I'm upgrading the heads to a set of Mamo 235 NFI and a Mamo cam........which should be significantly better than a good set of 243's. You might have just motivated me to start getting the work done, lol.
Motor:
LS2 block with stock bore and stroke
Callies Rods, Wiseco pistons, ACL bearings
9.5:1 Compression
ARP main studs
Custom turbo cam
LS3 oil pump, new timing chain
LS7 lifters
243 heads with Manley SS valves, 3 angle valve job, Patriot Gold springs, titanium retainers
Stock rockers with Trunion upgrade
Ls2 intake manifold and throttle body
ARP head studs
Turbo Kit:
Forced Performance TD06 20g's upgraded billet wheels (70/lb min per) with big compressor covers
Clipped turbine wheels
Turbosmart BOV
Tial wastegates
All SS boost lines
Turbowerx Scavenge Pump
Magnaflow exhaust with electric cutouts
Moroso Breather tank
Fuel/Spark:
1700cc Injectors
Racetronix 680lph Dual pump
PTFE -8AN feed
Aeromotive rails
Fuelab FPR with -6AN return lines
GM Truck Coils
#88
Street car takeover is here in Denver in a few weekends and I'm hoping to hurt a lot of feelings from the out of towers who don't know theres 2 snails hanging underneath haha. Hard to hear them over that cam/exhaust until it's too late.
