. . .w i d e b a n d. . .
Old Aug 4, 2009 | 03:58 AM
stol3n's Avatar
stol3n
Default . . .w i d e b a n d. . .
okay now i'm having a tough time picking between the following. can someone please tell me if there are any significant differences in the two or why i should justify the extra cash for the Dynojet unit. thanks.
http://www.widebandcommander.com/wbc_productinfo.aspx
or
http://www.autometer.com/cat_gaugede...gid=3606&sid=4
Old Aug 4, 2009 | 07:18 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I don't care for the Autometer widebands. They're too slow and you might as well forget about trying to do cold idle tuning or monitoring. I also don't care for the 0-4v output vs. the 0-5v.
I like Innovate and NGK for tuning.
Old Aug 4, 2009 | 08:25 AM
stol3n's Avatar
stol3n
i plan to let vengeance do the install & tuning for my FI kit but would like the comfort factor of seeing a/f once it leaves their shop. i want the autometer cobalt series gauges and i'm just trying to match them up best i can. i can get the:
autometer cobalt boost gauge
autometer wideband
autometer dual pillar
for $400 total to my front door. the price just seems too good to pass up for new stuff.
Old Aug 4, 2009 | 08:32 AM
TheBigDog's Avatar
TheBigDog
Take a look at the DB gauge kit
The Big Dog
Old Aug 4, 2009 | 08:33 AM
BLOWNBLUEZ06
Well considering the criteria, sounds like you've picked the right stuff.
Old Aug 4, 2009 | 08:38 AM
stol3n's Avatar
stol3n
The Big Dog
link?
from what i understand they both use the same Bosch o2 sensor. i'm not inclined to mess with anything related to electronics and FI on my vette, just feel if i am paying that much for a kit why not pay a few hundred to see what 's going on. cheap insurance at best, IMO.
thanks!
btw i love your vette, what a beast.
Old Aug 4, 2009 | 08:48 AM
exploder's Avatar
exploder
I only use the PLX Devices due to the unique gauges and also the ease of install. Only power and ground and plug in the sensor and your rolling.
Old Aug 4, 2009 | 09:20 AM
01vetter's Avatar
01vetter
I know that you like the Autometer looks, but you might want to consider other alternatives. I have the Innivate LC-1 with XD-16 wideband and it works great (fast and accurate). I also have the SPA duel fuel pressure/vacuum gauge and it also works great. Both the XD-16 and SPA gauge are digital and can be programmed with alarms. I have done this with the SPA gauge so that an alarm will flash if my fuel pressure drops below a given level. I also like the SPA feature that locks your maximumins so you can retrieve them. This is useful for checking maximum boost. I haven't programed the XD-16 yet, but it looks like you can program the gauge to flash if the AFR falls out of a specific range at WOT.
My experience with gauges is that things are happening pretty fast when under boost. It is hard to monitor the gauges and keep your eyes on the road at the same time. The alarms give added protection.
Old Aug 4, 2009 | 09:44 AM
TheBigDog's Avatar
TheBigDog
In you serach engine just type in DB Gauge kit and it will pull it right up
Dog
Originally Posted by stol3n
link?
thanks!
Old Aug 4, 2009 | 10:10 AM
ysb02's Avatar
ysb02
PLX for me
Old Aug 4, 2009 | 10:15 AM
user_name's Avatar
user_name
The autometer may not be the best thing out there for reasons mentioned above, but it is more than adequate. I used mine for all of my tuning.
Get what you like and then verify it's accuracy on a dyno with the shop's wideband.
Old Aug 4, 2009 | 10:25 AM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
The Wideband Commander 2 is the best!!!! It has built in programmable warning light and alarm-so if you don't see the light-you'll hear the alarm!
There expensive but well worth it.
Old Aug 4, 2009 | 11:17 AM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
link?
http://hinsonsupercars.com/s-452-wideband-sensors.aspx
We like the NGK for how accurate it is and the longevity.
Seth
Old Aug 4, 2009 | 01:47 PM
95vettski's Avatar
95vettski
NGK for me, affordable and accurate!
Old Nov 28, 2009 | 09:41 PM
Rhode Warrior's Avatar
Rhode Warrior
I've had nothing but trouble with Innovate. I ditched it a long time ago and have Autometers in both my supercharged truck and my Corvette. Great quality and very dependable. I like the looks too. I'm sticking with Autometer.
Old Nov 28, 2009 | 09:54 PM
Overboosted's Avatar
Overboosted
NGK AFX with the NTK sensor... can't go wrong.
Old Nov 28, 2009 | 09:55 PM
John-F's Avatar
John-F
Just curious regarding the Auto Meter limitations. I would like to learn more about this. Is it just your experience, or are you aware of any review that compared the different models, including the Auto Meter Nexus line in addition to Cobalt.
To . . .w i d e b a n d. . .
Old Nov 28, 2009 | 11:36 PM
hatewhatownsyou's Avatar
hatewhatownsyou
i hade an autometer in my mustang, i liked it. never had to calibrate it either.
Old Nov 29, 2009 | 03:42 PM
Brian@FI Performance's Avatar
0Brian@FI Performance
Former Vendor
From: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
Here ya go. AEM Uego
Brian
Old Nov 30, 2009 | 02:36 PM
HIGHRPM's Avatar
HIGHRPM
Check out the wideband setup from FJO Electronics...I've been using this system for over 4 years...no problems....very fast...very accurate.
http://www.alamomotorsports.com/FJO/wbafr.htm
