MAF update
Old Aug 15, 2009 | 09:50 AM
Blow Torch's Avatar
Blow Torch
Default MAF update
I've asked a similar question concerning the MAF before, but since I havn't completed my FI tune and it would be a "do it now or not at all" situation should I toss my stock size (early style) MAF and go with a larger 85mm ZO6 MAF, a truck MAF, or maybe a Delphi MAF that actually came with the procharger.
If it was just a drop in, it would be a no brainer, but when you consider the purchase cost of a MAF (unless I use the Delphi) different hose adapters, and the cost of the wiring harness to seperate the IAT, I need to know that it's worth doing.
I'm running a P1SC1 at around 9psi and 600+ hp
Thanks guys
Old Aug 15, 2009 | 05:17 PM
c5mtl's Avatar
c5mtl
i have a little less power and ive been advised to upgrade to the 85mm maf.....somebody is working on a 4 inch pipe that goes from the tb to the intercooler and will have a ls7 maf built into it..i think thats the best option
Old Aug 15, 2009 | 05:36 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
I have a brand new Z06 MAF that i would make a great deal on. it was only installed for a single test amd removed.
Robert
To MAF update
