Ok, car is getting baseline tuned today on a 97-00 MAF. However, I'm wondering if it's going to be a restriction when we crank the boost and do the full tune.
Would it be worth it to upgrade to a 85mm ZO6 maf or go one step further and do a later styled drop-in MAF in a custom housing??
you could call Taylor from Dallas Performance and get one of the bungs and MAF cards from him. You can weld or screw it to any pipe you choose. Very nice and clean looking.
Getting that setup in and running isn't the issue, my biggest thing is IF it's necessary. My tuner stocks the Sky Redline MAF which is probably the same thing as what everyone else uses seeing as how GM likes to use the same parts on different cars.
I have a 02 Z06 with the LS2 7.0 427 engine. I've installed to vararam air intake and a 90mm thottle body. Im thinking of changing my stock maf to a performance one. Do u guys no which maf would be best for my set up. I'd love to hear from u guys. FYI- performance transmittion, gears, clutch, and headers installed
Reason: spelling
Have you thought about losing the MAF with a SD tune, just a thought
I absolutely agee.. You are running out of MAF wayyyyy early in the run. The tuner is blindly adding fuel.
Ditch it all together. You have already gone way past the allowable limits.
Remember, a larger maf doesnt really give you the ability to run more boost. Although it gives you slightly more room in the tune, its nominal when your looking at 14psi on a forged motor. Your talking 2 to 3 thousand RPM's worth of blind tuning.
I am a fan of MAF tuning. I dont believe in immediatly ditching the MAF, unless its absolutely necessary. In your case, its absolutely necessary.
Originally Posted by user_name
14psi with a MAF on a gen3 pcm is a hackjob tune IMO. You need a 2-bar SD tune. Just my $0.02 from personal experience.
No, the placement is making them very lazy. I had an open loop 2bar tune on it before, my current tuner prefers MAF for economy purposes but isn't object to going SD. He said at 14lbs and a couple of HP Tuners add-in's he can get me fueled correctly all the way up. It'll be tight he says, but it's perfectly doable within the table range.
Im running the newer style MAF on my setup and its working great.
I like hearing this. Those newer ones have a bigger frequency range than the older stuff does. I just wish that my O2's weren't lazy given their positioning. Makes for fun low speed driving.
It doesn't matter. The PCM will only read 512g/sec. You have have MAF as big as a swimming pool, and it won't matter. You can scale the IFR table enough to fit 14psi into that range, but you lose resolution. If I'm running a significant amount of boost I want the pcm to know what boost actually is.
There is a big difference between what "gets it done" and what gets it done the best way. Tricking the pcm in a way that it does not see boost on a car with 10psi+ is asking for it imo.
Thats not a problem at all. In your tune, you can adjust the O2 switching in HPT. If your O2 sensors are placed in an improper area, and its throwing off the way they read, just scale it accordingly. This happens on some long tube header designs where the O2's are placed too far down in the header, causing them to read the exhaust pulses wrong.
Even when you run SD, you are going to run Closed Loop SD. This means that you still use your front O2's to adjust fueling. You dont even want to run Open loop SD unless your a diehard tuner that runs around with his laptop in his car 24/7.
