Idea...may be dumb
Old Aug 19, 2009 | 10:19 PM
jmoody66's Avatar
jmoody66
Default Idea...may be dumb
Ok so Im thinking....everyone says that boosted manual cars dont perform as well as automatic boosted cars because you lose boost through your blow off valve while shifting and you have to get it going again.....so in my case with an STS setup....
My thoughts, and Im sure someone has thought of this already, are to pipe your blowoff valve into the exhaust that feeds the turbos so that they tend to stay boosted or at least spinning more than if you vented it to the atmosphere. Seems to me that would just recirculate the boost pressure until the throttle blade opens and....well I think most will get the picture.
Anyone ever done this on an STS?
Old Aug 19, 2009 | 11:13 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I've read about this on other Turbo forums!
It's very similar to the INTERNAL wastegate, it is plumbed right back into the exhaust - try a GOOGLE search and see what comes up
Thanks,Matt
Old Aug 19, 2009 | 11:38 PM
CUZIWIN's Avatar
CUZIWIN
Wouldn't exhaust pressure be greater than boost pressure(for most people)? If so then wouldn't you end up pushing exhaust into your intake instead of intake into your exhaust.
Just a thought it's, late and I had a couple of drinks.
Old Aug 19, 2009 | 11:49 PM
highpockets's Avatar
highpockets
Nah,just keep it to the floor til your done ! Its called no lift shift,and it can get expensive fast ! Hows your car doing,didnt you get a stroker put in ?
Old Aug 20, 2009 | 01:29 AM
jmoody66's Avatar
jmoody66
Default You had to ask
My car.....oh my car.....well it does have a little stroker 402, hardened diff, built mn6, dte brace, pfadt motor mounts, cnc'd heads, roller rockers, hardened pushrods, ported fast 90, ls7 tb, twin disk clutch and aluminum flywheel......and yes its been since last September since this thing was dropped off but things have gone crazy and it wont hold a tune or something of that nature....been told by another person that the pcm grounds may be jacked up. So to answer your question about how my car is doing....I dunno.
Old Aug 20, 2009 | 02:15 AM
highpockets
Sorry,didnt mean to go there ! I feel for you,I spent several months chasing down various gremlins in mine before it would even break 50mph downhill.Trust me once its done,you will forget all about the past problems ! Good luck,let me know if I can help you out anyway !
Old Aug 20, 2009 | 05:01 AM
E.jones's Avatar
E.jones
Default .
I dont feel so bad about my car being in the shop now..
Old Aug 20, 2009 | 05:55 PM
tail_lights's Avatar
tail_lights
Mine was tied up for a while as well.
How goes it E. Jones?
Old Aug 20, 2009 | 08:36 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
[cough] [cough] Driver Error [cough] [cough]
Dont blame the car man. Thats like lasting 30 seconds with the girlfriend, and blaming the foreplay.. You just cant work it..
Old Aug 20, 2009 | 09:49 PM
highpockets
Lets run em ? I will be down tomorrow night ? Driver error my *** !How about cats that were so plugged it wouldnt make 4 psi with the wastegates bypassed. You know how these projects go, MR KB !
BTW,the clutch looked good,thanks !
To Idea...may be dumb
