HELP strange power cut please HELP
make a story short and the rebuilt is done , i took the car to the dyno and didn’t have one clean nor decent run tell know , my car is a corvette twin turbo LPE last i have made with it was 672WHP dyno jet with old set up.
PLEASE HELP ME , now i am in a big dilemma and i am lost , while the car is on the dyno and i am WOT to do a tune the car starts very smooth and accelerates great all the way up to about 4K RPM and some times 5K RPM and it cuts in a very strange way you can have a look at the video here under at the minute 1:01
You can see that something very strange happens and the check engine comes on for a moment and then disappears ?????????????????? :bang:
http://www.youtube.com/watch?v=tc3AiiiHO1k
Some thought was to a faulty Crank sensor, some a faulty Camshaft sensor, and some to faulty MAP sensor , when i did the DTC with the HP tuner it showed a miss fire but not permanent HELP
Here in video 2 you can see the tacho meter bouncing at about 5Krpm or so but the car did not CUT like it did the last couple of times but the tach bounced any gusses any takes HELP PLEASE
thanks
Please note this same thred was posted to ls1tech
http://www.youtube.com/watch?v=gE9ae...layer_embedded
have you checked codes ? and if so what are they ?
The misfire code which cylinder(s) threw the code ? P0307 would indicate cylinder 7, etc ..
thanks once more
Not sure if your problem is speed related or RPM related. Have you tried testing this by using other gears to see if it is speed or RPM related ?
If it's RPM related it could be a number of issues.
Bad Coil, wires, spark plugs, injectors or fuel related ??
