Alky meth kit
Aug 23, 2009 | 06:00 PM
Alky meth kit
What color should the led be when you hit the test light on the ECS Alky kit? Red or Green?
Aug 23, 2009 | 06:06 PM
St. Jude Donor '08
Mine turns red when the test button is pushed and when it sprays meth. I haven't seen the green light since i installed and checked it?
Aug 23, 2009 | 06:12 PM
Quote:
Originally Posted by
Corvette-Chris
Reason I asked was because it was green when I was doing the wiring up inside the car. I went out to were the pump was and starting zip tying the wires in place and noticed one wire to the pump was unhooked so I plugged it in and now its red when you hit test light.
Aug 23, 2009 | 09:15 PM
Red with the test button. Under boost it goes from red to green when the pump reaches full pressure.
Aug 23, 2009 | 09:19 PM
Mike04
That is pretty much what I see..
Aug 23, 2009 | 10:03 PM
cool I hope its working correctly! lol I wired it !
Aug 23, 2009 | 10:29 PM
St. Jude Donor '08
Cool, I don't think I've had mine under full pressure but I'll be sure to watch for it.
Aug 24, 2009 | 10:11 AM
just turn the **** all the way and hit test button and you will see it turn from red to green
