0068 code
Old Aug 24, 2009 | 08:06 PM
z06 vett's Avatar
z06 vett
Default 0068 code
i don't seem to have been given any breaks with this cars,other than breaking.
i had the cam bolts back out thing(thanks nick)fixed.then boost control,7lb. springs and removing the controller took care of that.
now at different times i get a p0101 alone or with a p0068.the tc codes show up too,1278,36,93.i all so get the left actuator ground codes,b0361 and others intermittent with the A/C,reduce power mode is the bitch.one day no code next all .could it the the weather?
i cleaned the MAF,tightened the TB,found a wire on the maf harness bare and wrapped it up.map looks good and vac is -19-20 at idle.the tune visit of three i had a still issue,he turned up the idle to 1100rpm.now there is a part throttle skip when cruising.
i ,again, have no tuner.he went to work at advanced auto parts.i do however have a diablo.can i tweak the tune made with efi live?it shows 11.2 afr on the dyno.when i stat it cold it is showing steady and rich.at 180 open loop kicks in and my afr is all over the place and pegs my lc-1 moats gauge to7.4 WOT.i put on another wide band on the road and saw 10.4 WOT
this is allot to read but i could again us the help.
mike in mobile
Old Aug 25, 2009 | 08:54 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
For the reduced power 0068 code ( which brings in the 1278 ), go to the engine diagnostics > 1514/0068 table and raise the values until the problem goes away. 4.10 is the max value. This table is a safety mechanism in the event the airflow doesn't match the predicted values. To the PCM, this would mean the throttle body is stuck open. Since you're F/I, you're exceeding the predicted amount of air flow.
Old Aug 25, 2009 | 09:54 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Which software are you using?
Old Aug 25, 2009 | 11:48 AM
z06 vett's Avatar
z06 vett
software?
i do not have any.( sold my hp pro)
my tuner quit the shop(efi live) and all i have left is a diablo.
sounds like a country song.
i have been asking around for hptuners.
weird it never coded until i repaired the cam bolt problem.
mike
Old Aug 25, 2009 | 11:52 AM
BLOWNBLUEZ06
Well, get out your favorite country album and get back on the HPtuners bandwagon or take it to a good tuner. It's not a difficult or even time consuming fix.
Old Aug 25, 2009 | 12:49 PM
z06 vett's Avatar
z06 vett
this why a bought a dyno.there are NO tuners here !!!!
i have been twice by trailer and once drove once to xxx motorsports florida and still it's not wright.the tuner quit.
can a diablo change that table?
i copied my tune without issue.
sure wish it could be done via net. by remote so you could do it.
anybody close by i and willing to help ?
i can drive to you.
mike
Old Aug 26, 2009 | 03:34 PM
z06 vett's Avatar
z06 vett
had a friend copy tune with hp .he will look at it tonight.
mikr
Old Aug 30, 2009 | 12:47 PM
z06 vett's Avatar
z06 vett
two weekends in a row i went on a left bank on ramp.80-85mph third gear ..pop code goes on.seems when i short shift third w/tire spin sane thing?
could i have to much oil in it?
mike
Old Aug 30, 2009 | 06:22 PM
BLOWNBLUEZ06
Did you change the table yet? If not, it's going to keep happening until you do.
Old Aug 31, 2009 | 08:04 PM
z06 vett's Avatar
z06 vett
i haven't heard from,
he was talking about drilling the TB?
he is comparing the tune yo a stock 04 ls5.he said my values were lower.
i will call again.
i sure wish their was a tune i could copy.
i will keep this going tell fixed
thanks ,
mike
Old Sep 5, 2009 | 02:41 PM
z06 vett's Avatar
z06 vett
i went ahead and put in a new z06 maf.fixed it!!!
seems the one that came with the car,west coast corvette modded,had a recal on it for the vararam and slp loudmouth sys.sure wish i new the history on this car.
thanks ,
mike in mobile
Old Sep 5, 2009 | 09:55 PM
BLOWNBLUEZ06
As soon as you finish replacing every nut and bolt in that car, you will!
Old Sep 6, 2009 | 12:35 PM
z06 vett's Avatar
z06 vett
YOUR PROBABLY WRIGHT!
ALL THAT'S LEFT IS THE QUARTERS,DOORS AND RIGHT FENDER. AND THE MOTOR IT SELF.
MIKE
To 0068 code
