Boost a Pump Question
Old Aug 27, 2009 | 09:50 AM
Hvymtlc5's Avatar
Hvymtlc5
Default Boost a Pump Question
At the point in HP now where I need to add a Boost a Pump.
My choice are: Kenne Bell, MSD, or Pro Charger.
I will be making about 675 RWHP. I do not want to run a return line if I don't have to.
Which of these BAPs is the desired setup using a Walbro 255 and 60lb injectors and the KB plug and play pump wire harness
Old Aug 28, 2009 | 06:11 AM
clif's Avatar
clif
St. Jude Donor '09-'10
I say a BAP is bad news. It overdrives your fuel pump and causes premature failure. You need to look at the RSI Dual Pump system to deliver all the fuel you need.
Good luck!
Old Aug 30, 2009 | 11:38 PM
Scubanme's Avatar
Scubanme
Good luck!
I tried searching for some info on RSI and did not find what I was looking for.
Old Aug 31, 2009 | 05:39 AM
clif's Avatar
clif
Check out his link. you will learn all about it:
http://forums.corvetteforum.com/c5-f...r-fueling.html
To Boost a Pump Question
