D1SC Cubic Inch limits.
Old Aug 27, 2009 | 10:26 PM
LostCauseZ06's Avatar
LostCauseZ06
Default D1SC Cubic Inch limits.
Alright, so seens how the crank in my 408 decided to break in half, i am going to be completing a massive rebuild this winter. The engine will obviously be a little more than 408 cubic inches after a rebore/hone.
I am planning on ditching the nitrous garbage and finally getting blown. I am just having a very hard time deciding which route to go.
I realize an F1 blower would be sweet, but what all is involved with getting one to fit on a D1sc/p1sc kit? does it bolt right up? is it even needed?
im planning on 800-900 rwhp. will a D1sc support this on a larger cube motor?
Old Aug 28, 2009 | 07:20 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
You probably already know the answer to this one, but the F1 is the way to go. I have seen a little P1 on a LS2 make 786, so a D1 can get you there as well. I am not Procharged, but I believe the F1 will bolt right up. Bob @ Exotic Performance Plus (EPP) can confirm this and is an excellent Procharger source.
Old Aug 28, 2009 | 08:00 AM
glennd's Avatar
glennd
I am at 858rwhp/780rwtq with a 416" at 9.2:1 C/R. Stock size damper and a 3.75" pulley. 15lbs. D1SC
Old Aug 28, 2009 | 08:05 AM
BLOWNBLUEZ06
D1 or F1?
Old Aug 28, 2009 | 09:57 AM
glennd's Avatar
glennd
Originally Posted by BLOWNBLUEZ06
D1 or F1?
OOps forgot the important part D1SC
Old Aug 28, 2009 | 12:07 PM
highpockets's Avatar
highpockets
Just do the F1 Chase ! You wont be happy until its the baddest vette around,the D1 will make you smile,but the F1 would be a killer setup !
Old Aug 28, 2009 | 02:23 PM
LostCauseZ06
haha it will never be the baddest vince, i have you to compete with lol.
Seems as though D1sc kits can be had for very very cheap. while an F1 blower alone is a few grand.
Just seems like there is no sense in going bigger and having "lag" as well as more parasitic loss to spin the blower when a tried and true D1SC can handle it just fine.
Old Aug 28, 2009 | 03:06 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Nothing wrong with the DS1C, my little 347 is at 750 rwhp and has been for 4 years, when I need a new motor, I will want a bigger head unit, and thinking about the F1A or F1C that Arun says works fine with the bracket I have, I have the latest bracket from A&A, works like a champ with my DS1C, good luck with the build
Old Aug 29, 2009 | 04:21 AM
dsmlights's Avatar
dsmlights
but what is the advantage of going bigger if the smaller will get you the power you want. I have a T tring on my car now and once i build a 408 why whould i upgrade, what would the advantage be. MY goals are 800-900 as well.
Old Aug 29, 2009 | 07:14 AM
EPP's Avatar
0EPP
Former Vendor
When you max out a blower it creates more heat than a blower that isn't spinning as hard. Take a look at this build and the horsepower we got out of it with an F-1A at just 12.4 psi of boost. There is also a lot of bottom end power there. http://www.exoticperformanceplus.com...Car.php?car=29
Thanks, I appreciate it. Bob
Old Aug 29, 2009 | 08:15 AM
dsmlights's Avatar
dsmlights
OK i understand that but are chargers like turbos, get a turbo to make the max power you want on the smallest turbo ???
I mean Even though the T trim might make the power @17psi and stuff will the power curve be better ???? I just want a good power curve ? I am sorry I am new to chargers
Old Aug 29, 2009 | 11:27 AM
tail_lights's Avatar
tail_lights
Old Aug 29, 2009 | 01:55 PM
EPP's Avatar
0EPP
Former Vendor
It makes sense what you are saying, but it hasn't worked out that way for us. The F-1A seems to start pulling just as soon as the P-1SC and the D-1SC. The F-1A is an all together different blower than the P & D series, it also has a 5.40/1 gear reduction instead of the 4.10/1 found in the smaller blowers.
Check out the torque at 2000 rpm on the dyno chart below. This is with an F-1A on an LS2/402 we built, with off the shelf AFR 225 heads and our EPP blower cam. This is in a CTS-V.
Here is a link to this cars build. Bob
Old Aug 31, 2009 | 12:53 PM
LostCauseZ06
thats slick. i anticipated alot more lag than that.
my buddy randy's 355 LT1 with an F1 blower has a bit of lag, but its also not 400 cubic inches feeding it. Thats pretty impressive that the power comes on just as quickly as a smaller blower.
Old Sep 2, 2009 | 09:38 AM
dsmlights's Avatar
dsmlights
ummmm man i wish i saw some dyno with a t trim or D1sc to see the difference in power.... Does anyone have one ?
Old Sep 2, 2009 | 10:31 AM
user_name's Avatar
user_name
I would also like to see it. I am curious how much power maxed out t-trims are making.
Old Sep 2, 2009 | 10:45 AM
glennd's Avatar
glennd
I will send a PDF of a D1SC dyno run to you if you can post it.
To D1SC Cubic Inch limits.
Old Sep 2, 2009 | 12:35 PM
fsuforever's Avatar
fsuforever
here is a question i keep asking myself, i am thru with a iron 402 build 9 & i comp & am running a chris novi 2k kit, theres gotta be a limit on how far i or ur wanting to go,for every sec in et time u drop the price gets very expensive ,so basically a 10.50 car & going to a 9. 50 car is gonna cost u some jack ,then ur gonna start getting into 10 ribs & cog drives & hell the next thing u know u cant drive the car on the street,i think the d1 would be fine for 800rwhp ,look what procharged automatic madmatt9471 has done with his car & hes running a forged 347, i think ur fine with the d1 in my personal opinion,peterpan is another one whos making 750rwhp thats nothing to sneeze @ either ,op ur car is capable of making more power & more tq just because of the bore size & because u opted to go with a 4.0 bore instead of the rebuild of a 346 or a 383,christwx is another car that makes big power with a 383 ,u can acheive 800 + rwhp with ur parts & ur motor with the right fuel system in my opinion
Old Sep 3, 2009 | 05:23 AM
EPP's Avatar
0EPP
Former Vendor
Here is an SLP iron block 402/AFR head engine with the SLP provided camshaft, and an D-1SC from a six speed Trans-Am.
Link to this car. http://www.exoticperformanceplus.com...Car.php?car=42 Bob
Old Sep 3, 2009 | 09:08 AM
fsuforever's Avatar
fsuforever
op another thing thats gonna make a big difference on hp is your cam selection, i had erik koeing build my motor 402 9 to 1 comp -32cc weisco pistons & a forced induction cam on a 117 lsa On Xer Custom grind comp cam & he made the decision on which cam to run, if i were u i would let him or someone thats been building these motors for a long time & knows what works,let them make that decision for u, I am not impressed with Slp stuff ,not knocking bob but if i were a betting man if the right cam was in that motor bob showed u the dyno graph on it would have made @ least 30 to 40 add meth & theres ur 800rwhp what i know i am just a tig welder heh,ask some of these guys on the forum who is one of the best engine builders in the country ,better yet email erik @ hke enterprises & tell hime ur situation & he will shoot u straight
