Blitz SBC ID II boost controller over boosting
Old Sep 11, 2009 | 02:27 PM
flash of red's Avatar
flash of red
Default Blitz SBC ID II boost controller over boosting
My car has been overboosting no matter what I set my EBC settings on. I unplugged the solenoid unit and boost only went to 7 lbs as it should with the 7 lb springs. I plug the controller back up and over boost happens. The vacume lines are in good shape. Controller has worked fine for over a year. I disassembled the solenoids...see if I could find anything obvious. They dont seem to be frozen up . I placed a test light to ground over their contacts and an audible closure of contacts can be heard and they stop air being blown through them when the contacts were activated in that way. Blitz help line wasnt very much help. They suggested I reset the unit. I will try that and see what happens. Any suggestions...these things are very expensive.
Old Sep 13, 2009 | 08:09 PM
vetteboy2k's Avatar
vetteboy2k
Sounds like a problem with the solenoids. Can't think of any other reason.
Old Sep 13, 2009 | 08:18 PM
Slow Z06's Avatar
Slow Z06
Check very closly the lines to your wastegate/s. Mine had a pin hole blowout and it would boost creep bad. Pull the vac lines off the solenoid, use an air hose on low pressure and fit it to the hose. listen for leaks. Also listen to hear that your wastegates are opening and closing
Old Sep 13, 2009 | 11:07 PM
flash of red
Well I am surprised. I did the system reset at the bottom of the menu which I had forgotten about...seems to have fixed it. I think the calibration had gotten off set somewhere along the line.
Old Sep 14, 2009 | 06:53 PM
vetteboy2k's Avatar
vetteboy2k
Cool to here, glad your all fixed up!
To Blitz SBC ID II boost controller over boosting
