60lb motron injectors
Old Sep 14, 2009 | 04:32 PM
denscor's Avatar
denscor
Default 60lb motron injectors
How much Hp can the motron injectors support?
Old Sep 14, 2009 | 05:17 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
We've pushed over 800rwhp 800rwtq. Anything above that, and i'd switch to the 80's. Actually, if you haven"t bought them yet, i'd go to the 80's immediatly.
Safely, I would run high 600's to mid 700's
Old Sep 14, 2009 | 06:17 PM
denscor's Avatar
denscor
With my car having 820Hp I'm on the line? Would this be a reason why the car is hard to tune?Its maxing out the injectors?
Old Sep 14, 2009 | 06:23 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
"hard to tune" meaning at WOT and the upper RPM's? Look at your injector pulse width at top RPM's. It is maxed out around 19ms. Even if you command more, it won't pulse any more than the time that's available in that window. The other thing is what is your fuel pressure reading up top? That will affect your ability to tune upper WOT if your pumps are unable to supply the volume.
Old Sep 14, 2009 | 06:26 PM
MotleyDrew's Avatar
MotleyDrew
Mine were AT 110% wot @ 6700 RPM AT 12.5 LBS OF BOOST. That was 770rwhp.
Fuel system is a in tank 255lph and an external 255lph. I now run 80's but have not been to the dyno since.
Old Sep 14, 2009 | 06:39 PM
denscor's Avatar
denscor
Fuel pressure stays at 60 all the way up top. yes its at 19ms so a set of 80lb are what might be needed.
Old Sep 15, 2009 | 04:02 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
Hey buddy, Yes, you definately need injectors..
I think we are just about the cheapest around. We typically stock 5 or 10 sets of each. If you need a set, I'll hook you up.. If you get a set in the month of Sept, ill sell you a set for 369.00 SHIPPED. These are the Mototron (Siemens Deka) 80lb injectors with the EV1/Minitimer connector, and long body design.
That is a serious serious hook up deal.
Just call in to the shop, and tell them that I ok'd it, and they will get them out for you.
Old Sep 15, 2009 | 09:10 PM
denscor's Avatar
denscor
I have a ls7 intake with the adaptors to use the ls1 injectors is this what I need?
Old Sep 15, 2009 | 09:40 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I would try a set of the 80lb SIEMENS DEKA injectors - they are High Impedence and work well with our PCM's
Thanks,Matt
Old Sep 16, 2009 | 02:37 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
Are you running long body, or short body injectors?
Old Sep 16, 2009 | 02:05 PM
95redz's Avatar
95redz
My build probably makes 770rwhp @ 13psi w/ a 70/30 water to meth spray and I'm maxing out the mototron 60lbers that are in the car. I have the 80s to put in as well I need to vacuum reference the regulator on my return style fuel system (A&A).
Old Sep 16, 2009 | 05:49 PM
denscor's Avatar
denscor
I'm running long ones! I will call you tomorrow and order them! I will tell them that you said to do it!
To 60lb motron injectors
