Worth it?
Old Sep 18, 2009 | 11:29 AM
z06sicz's Avatar
z06sicz
Default Worth it?
Is it worth it to run a FAST intake and larger TB for FI on a stock bottom end? I would think it should make more power with less boost and be easier on the motor??
Old Sep 18, 2009 | 11:37 AM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I wouldnt, but worth it is relative to the buyer.
I actually sold my PORTED FAST and switched to a stock LS2 intake when I went FI and I make great numbers
Old Sep 18, 2009 | 12:04 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Many people have issues with the FAST being that it is a 3 piece design and being Forced Inducted - They tend to leak!
Really a LS6 mainifold and even the LS1 and a LS2 on a FI set-up works very good! When you are FI a lot of factors that help Naturally Asperated motors don't do the same thing for Forced Induction - it kinda goes out the window, so to speak
I have 701 RWHP and 582 RWTQ on my LS6 manifold!
Thanks,Matt
Old Sep 18, 2009 | 12:32 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Jay (4DRUSH) went 9.1 with a stock LS6 intake and stock throttle body... Any questions?...
Old Sep 18, 2009 | 12:33 PM
Brandon619's Avatar
Brandon619
From my with experience FAST intakes on my Procharged set up is that they flow very well. I've never had an issue of them breaking under hard boost or sealing issues. Most problems with FAST intakes is improper installation.
Old Sep 18, 2009 | 12:59 PM
tail_lights's Avatar
tail_lights
Old Sep 18, 2009 | 01:25 PM
undertaker's Avatar
undertaker
From: ECS : WTF did you break now and HTF did you break it this time
Old Sep 18, 2009 | 03:57 PM
z06sicz's Avatar
z06sicz
Good to know; thanks for saving me the time and money.
Old Sep 18, 2009 | 04:01 PM
mdhmi's Avatar
mdhmi
And Harlan went bottom 8's with an LS6 intake and a forged 346.
I look at aftermarket intakes as just another way to waste money.
Old Sep 18, 2009 | 04:21 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Its just an alternative way to make power. In most cases, you can accomplish solid power, with minimal mods, on a boosted application. But that doesnt stop people from adding heads, headers, valvetrain, cat back exhaust, etc etc etc..
Is a FAST intake and larger TB a MUST?? Nope..Is it just another way to add more power? Yup.
Think of it this way.. Any way you can make more power, and limit the amount of boost, is a good idea. From a pure mechanical functionality standpoint, it is significantly safer to make all the power you can with the motor, then top it off with the power adder.
But at the end of the day, you can make the exact same power by turning up the wick.
The FAST leaking issues come from improper (Inadequate torquing) torquing, which causes leaks. They DO come slightly tweaked from the factory, and do require a tad more torque to seal them. When a person goes by the GM guidelines, they will tend to leak.
HTH
Old Sep 18, 2009 | 08:17 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Thanks,Matt
Listen to the All-Knowing ---grasshopper.
LS-6 intake with PP trottlebody-525/500
Old Sep 18, 2009 | 08:29 PM
z06sicz's Avatar
z06sicz
HTH
This was my original idea. I'm new to FI so I was thinking wouldn't it make sense to make more power with less boost. Basically I'm looking to take it easy on the stock bottom end, but still make great power (upward of 550 hp). Or is north of 550 no matter how you make it asking too much of the stock bottom end???
Old Sep 18, 2009 | 09:05 PM
2003VETT's Avatar
2003VETT
From: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
I've gone 9.82 on stock LS1 intake and throttle body. (and stock bottom end / heads)
Old Sep 18, 2009 | 09:47 PM
user_name's Avatar
user_name
I sold my 90-90 setup when I went to FI. They may make the numbers, but they are POS's as far as quality goes. Definitely not worth $1,200 on most FI setups. The money is better spent elsewhere. I'm not even sure i would run one on an FI build with no budget.
To Worth it?
