PLX gauges... anyone use them?
Old Sep 18, 2009 | 01:54 PM
Smoove's Avatar
Smoove
Default PLX gauges... anyone use them?
I saw them last year at PRI in Orlando,.. looked like a nice gauge setup. We're about to order a wide band multi gauge setup from them but,..just wanted to get some feedback and to see if a vendor here sells them. Heard some good things through the grapevine but nobody local.( plxdevices.com)
Thanks,..
Old Sep 18, 2009 | 02:05 PM
ysb02's Avatar
ysb02
Using their wideband sensor only with HP Tuners but seems nice. I wanted to do a setup with two of their digital gauges, are these the ones you're asking about?
Old Sep 18, 2009 | 02:50 PM
digivex's Avatar
digivex
Yes, I'm using them: Two A-Pillar mounted PLX Devices DM-100 multi-function, full color, remotely controlled, organic displays, which are fed by four PLX Modules: (a) OBD-II, (b) Vac/Boost, (c) Fuel Pressure and (d) AFR. Additionally, the pods contain alcohol pressure status (green/red) and secondary fuel pump system activation (blue) LEDs.
I also have an Innovate Motorsports LC-1 Wideband 02 Kit for logging & tuning using EFI Live V2. That wire sits over in the passenger side to connect into my laptop.
Only issue I have had was (1) one bad display, which they replaced and (2) FM radio interference, which can be a pain if you are at the track, listening to the radio to be called to the staging lanes while the gauges are on.
Smoove's Avatar
Smoove
If your showing a picture I can't see it at work so, sorry bout that.
It's the PLX multi gauge, "200" I believe. It is digital,.. and can have a multiple style backround,.. which you can download or they will even custom make for you to match your own cluster/interior.
Old Sep 18, 2009 | 02:56 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
WOW.. I am loving that interior.
Can you PM me what type of Sparco wheel that is?
Old Sep 18, 2009 | 03:07 PM
digivex's Avatar
digivex
Hey Jeff, I PM'ed you a few days ago about your rear flares for C5 and me stopping by to say hi when I'm in Vegas... Where are ya?
That wheel is the Sparco Mugello, See: http://www.sparcousa.com/psteering_street.asp?id=290
I use the button on the left for my horn and the one on the right for my transbrake
Sorry to take the thread off topic for a second... Now, back to PLX
Old Sep 19, 2009 | 12:46 AM
396375's Avatar
396375
St. Jude Donor '08-'09
So what do you do about the radio interference on the street?It would suck to turn off the gauges to listen to the radio.
Old Sep 19, 2009 | 03:21 AM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Old Sep 19, 2009 | 06:55 AM
clif's Avatar
clif
St. Jude Donor '09-'10
I have three DM-200 displays, as well as their Wideband module, their Oil Pressure module ( that I use as a fuel pressure module), and their vacuum/Boost module. One of my DM-200s is also the OBDII version so I can watch all the internal parameters in the PCM.
I removed the gages from their cases and had Beers make a custom plate for me. Here is the finished project:
Here is one as it came in the box:
Here is the AFR module with the vacuum boost shell below it:
All three display modules:
Here is the plate getting fitted:
and the remote:
Old Sep 19, 2009 | 04:39 PM
digivex's Avatar
digivex
If you listen to a lot of FM radio, it would suck (at least in my case). I am sure you could wrap the wires causing the interference to block it.
I am not sure if others using the PLX gauges have encountered the same FM radio interference or not. It may depend on what sensors you're running. I have not spent much time trying to isolate the exact wire that would need to be shielded.
I like the displays and flexibility they offer. I also like being able to pull peak readings after taking a pass in the car, etc.
Old Sep 19, 2009 | 05:56 PM
396375's Avatar
396375
I've always liked those gauges.
Good luck.
Old Sep 19, 2009 | 06:05 PM
clif's Avatar
clif
I do also get a lot of noise from my PLX system on the radio
Old Sep 19, 2009 | 07:50 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
and the remote:
That is DANG slick right there. Good way to do a stealthy install though, which you have me seriously pondering at this point.
Old Sep 21, 2009 | 03:30 PM
ysb02's Avatar
ysb02
Are they on separate power / ground wires or sharing?
Old Sep 21, 2009 | 03:33 PM
clif's Avatar
clif
they are all using the same power and ground wires from the BCM. There is a spare power wire from the BCM that I am using.
Old Sep 21, 2009 | 04:11 PM
exploder's Avatar
exploder
I have never had any radio interference with mine, but I have mine mounted on the steering column and they wires do not get anywhere near the radio wires.....
Old Sep 23, 2009 | 09:53 AM
Smoove's Avatar
Smoove
Interesting.
To PLX gauges... anyone use them?
