I have a 1998 Automatic Corvette. Last winter I forged the bottom end of my motor with Eagle Forged H Beam Rods and Mahle Pistons. The car has AFR Mongoose 205cc heads 66cc, 226/234 .598 .599 117 lsa blower cam, Procharger P-1sc-1 ho kit with a 3.70 pulley on it. I took it to Straightline Performance for tuning and we found that the boost is jumping up to about 4lbs and then dropping off to 2lbs. I have ruled out belt slip as I had a new tensioner made to give me a lot more belt wrap. I also went through and rechecked all of my hose fittings from the supercharger to the intake manifold. Any ideas or suggestions as to what to do next?
Here are some screen shots from the dyno:
Belt slip doesn't always occur at the charger. It can also occur at the balancer.
If it is absolutely not belt slip, do a pressure check. Cap off the inlet and pressurize it. Listen to your bypass valve. It's a common point for leaking in some systems.
After that, it's anyone's guess. Balancer not pinned and spinning on the crank or who knows what.
You prob found the limit of your 6-rib belt.
I would also concur about doing a pressure check as Bret has stated as he is one of the most knowledgeable people on this board!
The balancer spinning on the crank was a way-off statement. More b.s. than anything. The other 2 are the main issues. Have also seen intake leaks, broken rings and pistons causing the loss of boost.
FAST are notorious for leaking and cracking, especially under BOOSTed conditions!
It is quiet possible you have a crack in the manifold even if it is the stock LS1/LS6 - time for a close inspection
Other than that I'd seriously inspect the belt at the crank and do a WOT pull and watch the Volt gauge to see if it drops which will = Belt slip @ Crank (This is a tried and true method to see whether you have belt slip indeed - ARUN's Method is waht we shall call it )
4lbs is not very much even for a P1. Like the others have said never rule out belt slip. As far as other possibilities, it would help to pressurize the entire system and see if there is a leak somewhere, especially at the valve.
Thanks for all of the help guys. I brought it by a buddy who has a fog machine and can pressurize the system for me. I will keep you all posted on what he finds.
Im the same problem. i have a vortech v1 t trim and with a 6' crank pulley and the 3.33 vortech pulley i only made about 1.5 psi so i bought a 2.95 vortech pulley and it made 5 psi.
Mine was making 6.5 psi with a 3.85 pulley before I forged the motor.
6" crank pulley? sounds like a hella under drive pulley!
