LS7 clutch install help please
Old Oct 6, 2009 | 03:02 PM
whitelite's Avatar
whitelite
Default LS7 clutch install help please
Took my C5 clutch out of the bottom of the bellhousing but the C6 Z06 (LS7) clutch won't fit back in without removing the bellhousing.
Am I missing something or is the LS7 clutch just a little bigger and requires removal of the bellhousing?
Thanks, Randy
Old Oct 6, 2009 | 04:30 PM
Smoove's Avatar
Smoove
Thanks, Randy
If you have them both out of the car, why don't you put one on top of the other and see if there is a difference.
And, are you talking about the inspection sheild/plate? Your trying to remove and sneek in a clutch through that? Try some vasaline.
Try this, remove the the FRONT cradel REAR bolts, looesn the front ones half way, and remove or simply loosen the bellhousing. Your already there, might as well spend another ten-15 minutes and do it like that.
Old Oct 6, 2009 | 04:35 PM
HP_Addict's Avatar
HP_Addict
It only takes about 15 minutes to remove the bellhousing. Plus it makes torquing the clutch bolts down much easier. Now the hard part is putting the bellhousing back on. You will need some swivel sockets and a long extension and some patience.
Old Oct 6, 2009 | 05:14 PM
user_name's Avatar
user_name
Have fun. That bolt up by the fuel lines is INSANELY hard to get on and tightened...lol.
Old Oct 6, 2009 | 06:56 PM
leo12's Avatar
leo12
Thanks, Randy
it will keep moving it around in deferent angles it will eventually go in dont loose your cool
Old Oct 6, 2009 | 07:21 PM
whitelite's Avatar
whitelite
Are you saying the LS7 clutch will fit without removing the bell housing???
Old Oct 6, 2009 | 08:13 PM
RoadRebel's Avatar
RoadRebel
Yes, All you need to do is drive in the pins in the flywheel as far as you can. Then rotate the flywheel till 1 pin is near the top and the others are at roughly the 3:30/8:30 position. slip the flywheel up and in first then slide the disc in between.
Old Oct 7, 2009 | 10:27 AM
whitelite's Avatar
whitelite
Thanks Phil....
To LS7 clutch install help please
