GOING FI- need advice
Old Oct 8, 2009 | 01:15 PM
zeevette's Avatar
zeevette
Default GOING FI- need advice
I've got a full bolt-on H/C Z, that's @ 480 RWHP, and I just bought an A&A Vortech kit. (V3 SI trim) I'm having to de-mod some parts, like my Meziere EWP, and Powerbond UD pulley, but the thing I'm most concerned about, is the FAST 90 setup. The guys at A&A said to just trade someone ( I sold my original) for a LS6 intake/TB, because the FAST needs to be modified, and the durability under boost is questionable. I've got alot of $$ in my FAST, being ported, sensor relocation, etc., and though it'd be a simpler install, and maybe tune, to go back stock, would I be leaving alot of HP on the table?
Old Oct 8, 2009 | 01:30 PM
n2osage's Avatar
n2osage
Are you running stock compression in this set up as well? Are you going to use good gas or meth? I ask because if you're making 480 rwhp with stock displacement, then I imagine you're also running a bit of compression.
If that's the case, and you're only going to be running very low boost (7psi?), I wouldn't worry about it. How much boost/power do you hope to make?
Old Oct 8, 2009 | 01:34 PM
robert miller's Avatar
robert miller
The fast seems to have no problem until 14 plus psi.
Old Oct 8, 2009 | 01:48 PM
glennd's Avatar
glennd
I am running a ported FAST 90 intake at 15lbs. I have heard of these having problems with boost, I don't know how many of the reports might be of the same unit. I also have 2 pop off valves set to 18 psi at my throttle body, this is in addition to my blow off valve. This should help reduce any high pressure spikes during shifting.
Old Oct 8, 2009 | 01:54 PM
user_name's Avatar
user_name
The FAST is definitely junk quality compared to OEM. That much is hard to debate. I ditched my 90/90 when going FI just for the cost/hp reason. Money was better spent elsewhere. No regrets.
Old Oct 8, 2009 | 02:06 PM
tlove32's Avatar
tlove32
I have H/C and a FAST92 (stock block)...I kept the FAST. Being that I'm still on stock pistons, I kept the boost low (7psi) and the tune conservative (10 degree timing).....580rwhp/520rwtq.....and its a blast.
When the time comes for a forged motor and more boost, the FAST intake will probably be traded for an LS6
Old Oct 8, 2009 | 03:37 PM
zeevette's Avatar
zeevette
This is about the same as my position. I'm at 10.9:1 CR with 61cc heads, and at this point in time, don't foresee going with more than 8 lbs of boost. If and when the day comes to forge, I'll drop the CR with dished pistons, because I want to keep my Trickflows. AFAIK, the only modification needed to retain the FAST will be to flip the TB, and relocate the PS res.
Old Oct 8, 2009 | 05:21 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Believe me you will be fine under BOOST with the LS6 manifold and you will not be leaving a ton of HP on the table
Under BOOST the LS6 performs very well and will stay in one piece, if you feel you need more RWHP then pulley down and it'll BOOST up and you'll tune for the extra HP.
Why are you ditching the EWP? I have one on mine and it is great, although I do not track the Vette.. 701 RWHP and 582 RWTQ
Thanks,Matt
Old Oct 8, 2009 | 05:43 PM
Z06wanted's Avatar
Z06wanted
I have a fast on my setup 9 psi 708rwh and 674rwt. No problems so far.
Old Oct 8, 2009 | 06:26 PM
zeevette's Avatar
zeevette
Thanks,Matt
I think you misunderstood a little, Matt. I have the FAST, and was told by A&A to switch back to stock (Which I no longer have) LS6 mani. I'm pretty sure I could trade intakes easily through the forum, but since I already have the FAST dialed in, should I bother? On the EWP question, the guy @ A&A said it wouldn't fit with the SC bracket setup. I can easily switch back to stock, and sell the EWP, but A&A said it wouldn't fit??? I'm gonna be down there pinning the crank pulley (and changing it back to stock one) so do I REALLY need to change cams? I run a Crane 228-232 @ 112+5 and .600/.600 lift, BTW. Once again, I'd like to retain the cam if possible because it performs well NA, and has a nice lope, too.
Old Oct 8, 2009 | 11:12 PM
tlove32's Avatar
tlove32
We run very similar setups. I have Trickflow heads and a 228/232 cam (115LSA). You'll be fine.....just don't go crazy on the tune. My tuner said these piston are at there limit at around 600rwhp....so he made sure to keep it below that
Old Oct 10, 2009 | 12:44 AM
Scubanme's Avatar
Scubanme
My advice is to have lots more money to spend than you originally anticipate. Have even more patience when having any work done at a shop. F/I has a bunch of issues, going to the LS-6 manifold works very well and no leak issues. You will not be leaving too many HPs on the table.
Old Oct 10, 2009 | 06:55 AM
madmatt9471
WOW! That's a pretty hefty cam
You should be fine. I am suprised at the EWP I run one on mine with the A&A Bracket and have no issues!
I realized you have the FAST now but I was simply saying the LS6 will do good if you choose to switch - I would IMHO!
Thanks,Matt
Old Oct 10, 2009 | 09:04 AM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Thanks,Matt
I still run a LS1 Intake Manifold just haven't been motivated to change it or spend the money
Old Oct 11, 2009 | 02:07 AM
c5mtl's Avatar
c5mtl
i got rid of my fast 90/90 and went back to my ls1...not even ls6....now moving up in the hp levels and going to hold on to my ls1.....
To GOING FI- need advice
