D1 with 11:1 comp LS1???
Old Oct 10, 2009 | 03:26 PM
THEPUNISHER97VETTE's Avatar
THEPUNISHER97VETTE
Default D1 with 11:1 comp LS1???
I have a 97 LS1 vette with afr 205's 11:1 comp and mild GT2 cam. I was thinking about buying a D1 run meth with about 7psi. Its the stock bottem end with almost 130,00 miles on it. I wanted to see if it would be safe to run like that? Any help is appreciated...
Old Oct 10, 2009 | 04:02 PM
leo12's Avatar
leo12
it will work for a couple of miles...too much comp too many miles
Old Oct 10, 2009 | 04:07 PM
THEPUNISHER97VETTE
Ok thanks man
Old Oct 10, 2009 | 07:10 PM
rplaster's Avatar
rplaster
Put it on and run it till it blows.
Old Oct 10, 2009 | 07:55 PM
user_name's Avatar
user_name
You really can't say that for sure. You can run moderate boost through it no problem. Meth would be best. You will find out if the motor is worn or not.
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
i think you could get by with 5-6 # boost... prolly not for long tho since its a stock bottom end.
i have a forged 427 with 11.9:1 CR... i am planning on boost this winter, 10psi and e-85. i have been told it should be ok...
Old Oct 10, 2009 | 08:46 PM
69dodgecharger's Avatar
69dodgecharger
I think alot will depend on how much CP that cam bleeds off. Also I would recommend running a P1 on that engine especially at that low level of boost
Old Oct 10, 2009 | 09:06 PM
robert miller's Avatar
robert miller
Dont go over the pulley that comes with the kit for sure. Have some fun.
Old Oct 10, 2009 | 10:01 PM
THEPUNISHER97VETTE
Ok what do you guys recommend would be the safest FI route without messing with the heads pistons etc.???
Old Oct 10, 2009 | 10:26 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
D1 with a 5" pulley
Old Oct 11, 2009 | 12:49 AM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Dump the Afr's and buy some 317 heads to bring your CR ratio down. Then you can run 11psi with meth and make some great safer power.
Old Oct 11, 2009 | 01:13 AM
THEPUNISHER97VETTE
Thats what I wanted to do but, the cost of labor to switch the heads out would be a lot and I dont have enough mech. skills to do it myself. Im torn...
Old Oct 11, 2009 | 01:16 AM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
The AFR"s are worth about $1000.00 to $1200.00 sell them and pick up the 317's for about $250.00 then buy headstuds,gaskets and have some money left over for labor. You might also needs BAP.
Old Oct 11, 2009 | 01:19 AM
THEPUNISHER97VETTE
Yeah that sounds pretty good I think I might do that then I can drive my car to work not having to worry If I need to call a towtruck lol wouldnt be funny if it happened though.
Old Oct 11, 2009 | 07:54 AM
EPP's Avatar
0EPP
Former Vendor
http://www.exoticperformanceplus.com...Car.php?car=39
Take a look at the above link. The customer had us build the engine for N/A, the next year he ended up wanting to add an APS twin turbo system. Turbo's typically require a lower compression ratio than a centrifical supercharger. We didn't go crazy with the boost, but it worked out very well. Bob
Old Oct 11, 2009 | 10:23 AM
leo12's Avatar
leo12
I am sure you can run a bit of boost for a bit.. but he will loose that motor fast the meth will help but the first shot he steps on it and for some strange reason or other the meth dont come on BOOOMMM there goes the motor,
Not sure if its worth all the headaches
Old Oct 11, 2009 | 11:09 AM
user_name's Avatar
user_name
If you say so.
It's been done many times.
To D1 with 11:1 comp LS1???
Old Oct 11, 2009 | 12:48 PM
tail_lights's Avatar
tail_lights
I can be done The tune will probably determine how long it'll last. 5-7lbs can be safe but I wouldn't let the tuner add meth for power, just safety That way if the meth does not fire you'll still be ok, but when it is spraying it should be very safe. That being said as far as longevity its really a crapshoot. Guys run stockers and boost to over 650 here (not the norm, but it happens) with no problems. Mine had problems and I was only at 507
Good luck!
Old Oct 11, 2009 | 01:05 PM
THEPUNISHER97VETTE
Man I wish I was closer to you I would just have you re-do everything and basically build it for boost. Ive had it boosted before not too long ago I had a maggie 112 pushin 6 psi with no problems Im just not sure that centri. blowers like the high comp. cause the maggie did.
Old Oct 11, 2009 | 02:05 PM
user_name's Avatar
user_name
Stock ls2's are 10.9:1. I don't know what to tell those saying 11.1:1 is too high except you don't know what you are talking about and haven't tried it yourself. Correct me if I'm wrong.
