View Poll Results: What Tune System
Maf 1Bar
8.00%
Maf/SD Hybrid 2Bar
8.00%
2Bar SD
24.00%
3Bar SD
60.00%
Voters: 25. You may not vote on this poll
Big Boost, What Tune?
Old Oct 13, 2009 | 08:04 PM
Slow Z06's Avatar
Slow Z06
Default Big Boost, What Tune?
What are you big boost guys ( 14psi + )using for your tunes? With or without meth?
maf
2bar SD
3bar SD
Old Oct 13, 2009 | 08:28 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Your right on the edge on a 2 bar. Just do a 3 bar closed loop SD tune.
Dont waste your time on a MAF tune. Your flyin blind with that kind of boost.
Old Oct 13, 2009 | 08:35 PM
user_name's Avatar
user_name
Old Oct 14, 2009 | 08:55 PM
Vince99FRC's Avatar
Vince99FRC
3 bar here....
Old Oct 14, 2009 | 09:14 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Just convereted to 3 bar and Vette runs better, now I just need to solve the fuel issue that has popped up with more power
Old Oct 14, 2009 | 09:15 PM
Slow Z06's Avatar
Slow Z06
3bar it shall be then. Does anyone know off hand the part number to the 3bar sensor i would need?
Old Oct 15, 2009 | 02:02 AM
dsmlights's Avatar
dsmlights
is there not a 2.5 bar map out there... the only thing I don't like about the 3bar is that it does not fit directly into the manifold.
Old Oct 15, 2009 | 11:21 AM
Brandon619's Avatar
Brandon619
I've been running a 2 bar SD for 2 years now and love every minute of driving
Old Oct 15, 2009 | 01:43 PM
Z06wanted's Avatar
Z06wanted
3 bar here. If your running a 2bar and go past 14psi then it's no different than running a maf IMO.
Old Oct 15, 2009 | 06:25 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Im running a 2bar MAF but my peak power doesnt reach over 14psi.
Old Oct 16, 2009 | 12:28 PM
Jason Blue Boost's Avatar
Jason Blue Boost
2 bar SD with 13 to 14 lbs. Run a mix of 100 octane with high setting only. Any higher than that and I'll have to get a newer pcm.
Old Oct 16, 2009 | 12:44 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Heck I don't have a choice on my Vette I had to do a 2 BAR SD tune w/No MAF!
But if you are able to do a 3 BAR then I'd have the tuner tune it that way, that will enable you to have a "HUGE" table of tunin g peramiters for the Vette
Thanks,Matt
Old Oct 16, 2009 | 12:51 PM
mulalleybs's Avatar
mulalleybs
I have a MAF tune with 11 lbs of boost. Are there any issues with this? I heard SD tunes are bad for places with large temp changes. I don't really know anything about it though to be honest.
Old Oct 19, 2009 | 09:01 PM
z0quick's Avatar
z0quick
We are running just under 800rwhp on our shop sts twin turbo c5 on a 2bar map (SD) with in dash eboost2 controller. Since we've tuned each cell, we can dial in the eboost to whatever level we'd like and there are 3-5 presets you can define. We currently have 3 presets on 7, 10, and 14psi. F the maf! The car is cam'd and we've got it idling like a dream.
Old Oct 23, 2009 | 04:31 PM
FreddyG's Avatar
FreddyG
If you go with a 3 BAR, here's the pn for the MAP sensor: 12223861
Old Oct 23, 2009 | 04:39 PM
Slow Z06's Avatar
Slow Z06
Thanks. Will that sensor plug in directly or do I need to adapt the wires to it?
Old Oct 23, 2009 | 05:47 PM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
Rob, Ontariovette, SudburyC5 and myself are all 2 bar, we don't make any enough JAM for 3 bar.
Old Oct 23, 2009 | 07:14 PM
robert miller's Avatar
robert miller
Arun, bro you are so full of it .. Have got that new 90 or 92 T.B. yet..That may slow you down.
To Big Boost, What Tune?
