Temp changes and tunes?
Old Oct 16, 2009 | 10:26 AM
mulalleybs's Avatar
mulalleybs
Default Temp changes and tunes?
I got my car tuned in FL at 96 degrees and 25% humidity. Pulled 591 rwhp on a dynojet.
I recently did a dyno pull on a dynamics dyno, because it was free, and did 598 rwhp at 77 degrees and 50% humidity. The guy on the DD dyno said my car was pulling timing.
What worries me is that the temps are very sporadic around here in Savannah. During the winter months it often goes from 40 degrees in the morning to 70 in the afternoon. While some days just stay 30ish all day. Should I be worried about the tune on my car?
My friend said I have nothing to worry about and that the computer will compensate for the change in temperature, but I was worried that a 50-60 degree change (96 to 40 and below) would cause something very bad to happen with my car.
Thoughts/opinions?
Thanks,
Brett
Old Oct 16, 2009 | 10:32 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
There are some tables that will help with temperature compensation with fuel and timing. The only problem is the tuner tuned it at that one temperature and most likely left the temperature modifiers stock since he had no way to tune at different temps. You might wait until it gets as cold as it's going to get and change those temperature compensation tables only and fill in the values in the temperatures in between. Was it pulling timing due to knock or something else?
Old Oct 16, 2009 | 10:36 AM
mulalleybs's Avatar
mulalleybs
What other things would cause it to pull timing? I would think if it were knocking the tuner would have said something.
The guy that tuned my car (Tony) also tuned Joe's Ford GT TT if you know who I'm talking about.
Old Oct 16, 2009 | 10:40 AM
BLOWNBLUEZ06
Don't know Joe, but burst knock table, IAT vs. Spark, Torque management tables.
Old Oct 16, 2009 | 10:41 AM
user_name's Avatar
user_name
There is a little guess work involved in making sure a tune is still safe when much cooler air comes along. Definitely give it a look in some colder air.
Old Oct 16, 2009 | 11:15 AM
mulalleybs's Avatar
mulalleybs
I think it was just because if IAT's but I really don't know.
A friend of mine and I had a "arguement" about temps and detonation last night and I decided to post to see what everyone else though.
Really don't want to blow my motor just because I want to drive it during the winter.
Old Oct 16, 2009 | 11:22 AM
Z06supercharged's Avatar
Z06supercharged
Even with the computer adjusting for colder temps your tune to run a little leaner ESPECIALLY if your area has "winterized" gasoline (more ethanol in it in the winter months and will make it .5 leaner afr's WOT).
I load a winter tune and summer tune here in Cal on my car because of the crap winter gas with 10% ethanol in it (and the gas I had tested actually had 12% ethanol in it which was even worse).
Old Oct 16, 2009 | 11:24 AM
user_name's Avatar
user_name
I load a winter tune and summer tune here in Cal on my car because of the crap winter gas with 10% ethanol in it.
We don't have that problem here in Texas. I believe that is just for foreign countries like CA.
Old Oct 16, 2009 | 11:26 AM
Z06supercharged
The Metro areas in Texas have ethanol in the gas as I saw a sticker on a Shell pump in Dallas last month stating it. Texas applied for a Ethanol waiver and they were denied it in 2008. Yes even Texas has fallen to the political environmentalist crap...
Old Oct 16, 2009 | 11:28 AM
user_name's Avatar
user_name
The Metro areas in Texas have ethanol in the gas....
We have 10% ethanol at all of the pumps around Houston. The blend does not change in a way that affects the tune. I've verified this.
Old Oct 16, 2009 | 11:32 AM
Z06supercharged
You wanna bet on that?
10% ethanol (E10) runs leaner than non oxygenated gasoline and it will reflect a .5 leaner afr because of it, It has a stoich of 14.1 and not 14.7 like regular gasoline. Do the math...A tuner should know this and adjust the tune for 10% ethanol in the stoich table input. Most dont though....
It was night and day noticeable on my tune when they switched over to winter gas here. Same exact thing to date as last year to me as well.
Do a google on stoich for E10 cause there is lots of reading out there on its affects on tunes.
Old Oct 16, 2009 | 11:41 AM
user_name's Avatar
user_name
Sure, but you misunderstood what I typed. I'm simply stating that the blend we have here in Houston does not change in a way that affects the tune. We have 10% ethanol year round and every pump. I've got logs from various dates backing this up.
Old Oct 17, 2009 | 12:17 PM
blkdevl's Avatar
blkdevl
i dont know cold but when i went from being tuned in seattle to when i moved to TX there was a big change in the way the car was running i got it retuned and run great again.
To Temp changes and tunes?
