Clutch
Old Oct 22, 2009 | 10:54 PM
C4Lee's Avatar
C4Lee
Navigator
Default Clutch
I plan on doing the following upgrades to my 2002 Z06 Procharger (6psi), Kooks headers. will a clutch upgrade be needed?
Old Oct 23, 2009 | 12:59 AM
95vettski's Avatar
95vettski
Most recommend a clutch replacement, but you can probably get away with your stock clutch as long as your on stock tires. If you race the car at the track with sticky tires forget it!
Old Oct 23, 2009 | 05:07 AM
MYLS6's Avatar
MYLS6
Im running just a few more pounds then you are, stock clutch lasted just about 10k miles or so on GY Tires. No track times no hard launches just some good ole street driving. I recently moved up to the Monster STG 3 and also got rid of the balding tires put on some R888's. IMO if you can afford it now and so on then go ahead and throw a new clutch in there of your choice or ride out the old one till it needs to be swapped out...all this obviously is dependant on your driving style.... hell stock clutch could last you a long time or could be smoked with in the first week!!
Old Oct 23, 2009 | 10:29 AM
Z06wanted's Avatar
Z06wanted
make sure to keep the clutch fluid changed out and if you replace the clutch put a remote bleeder in.
To Clutch
