No squeaks or squeals here. We started slipping at 5,000 rpm's on a 10-rib with all the tricks. Thanks to the Flip Drive 2, we were able to spin my F1R 110% with no signs of slipping. Highly recommend this product.
Originally Posted by yyzmsp
Yes and it still has all the stock accessories attached...
That's good to know because for many (most?), retaining one's streetworthiness is an important thing.
And if one is still able to do that AND maintain some real boost (ie: no belt slip) while also not destroying the various bearings/gears inside said accessories at the same time then it's a win/win situation.
Record times are being run with the Flip Drive. The fastest cars out there are using a Flip Drive or similar approach, the Flip Drive on the other hand is the only set up out there that let's you retain all your stock accessories in there original location.
Good luck on Friday at MIR Arun , wish I could be there , get that 8-second slip .
