I have a 408 that is making around 500 rwhp NA and 700 on nitrous (200 wet). I am running the FAST 90 and was wondering if I can pick up decent power with a front mount TB sheetmetal intake. I shift at 7K.
Thanks!
Lots of people have done it, and most take it back off.
Loose too much under the curve, for a small gain up top.
In the right application (drag car), it may be advantageous.
What if you got a twin turbo 427. With so much low end torque
will it matter much? If I am looking for top end power and more
traction, will a sheet metal intake make sense?
Sorry for the hijack.
Been there, done that, spent the 2600 bucks, and ripped it off within 2 weeks.
We lost 67rwtq, and gained 22rwhp. The car felt flat until over 5K. This was on my LSx 454.
I would do a ported 102, with a comparible TB. Dont waste your money on the manifold unless you are willing to spend the money on the TB. They just dont pick up enough power without it.
LPE installed a sheet metal intake in thier 1000+HP TT's.
But I'd suspect that's more for structural integrity at the high psi levels than increasing power.
Fast intakes have been known to catistrophically fail at over 15psi.
I've seen a bunch of posts with TT monsters or other FI cars building really beautiful sheetmetal intakes from scratch.. a bunch of them end up removing them for something that doesn't slaughter their low end so much..
If you got so much low end that you can't get any traction in 1st, 2nd,
and even 3rd, on some build, then why does it matter?
Didn't say it did, just stating facts after watching bunch of very nice hand made sheet metal intakes being taken off- it's not like it was my car lol.
You wouldnt happen to have a dyno graph would you? What intake where you running before? What where the runners like on the SM? Where they pretty short compared to a plastic intake?
Thanks!
Originally Posted by Higgs Boson
maybe I will pick up with a FAST 102?
The fast 90 is for cathedral ports and the 102 is for L92 style ports. Am I missing something here?
Tuner shown that a properly ported LS7 is very similar power gains to a 'out of the box' Fast LSx.
Not sure if there's any reliable data comparing a Ported Fast 92 cathedral intakes to Fast 102's.
But for wiw, the same tuner also only gained 5rwhp going from a 92mm TB on a LSx intake to a 100mm TB on the same intake. It's all on LS1Tech if you know how to search.
You may want to try a single plain first, they are much cheaper. Again, you will lose a little down low and gain a little on the top. I went single plain for strength, and I already was pumping out 685rwtq at 3500 rpm, so no problem loosing a little. I also added a plenum spacer for more volume and thus extend the top-end a tad bit more. My opinion is, once you get to a certain power level, dialing in where you need it most can be a benefit for some. Running a 6-speed, I don't care what happens down low because it's run as a drag racer about 90% of the time.
Robert
