STS Self Do'ers
Old Dec 10, 2009 | 11:40 AM
01QSZ06/3's Avatar
01QSZ06/3
Default STS Self Do'ers
So I figured this STS install would be pretty smooth sailing right? NO!!! I really wish that I could be part of the STS engineer team and design this thing myself. I'm an aircraft mechanic and it's kickin' my behind.
I noticed that the wastegates and the turbo gaskets came with 2 pair each. Is this in case you screw one up and you have a replacement or what? Also both the gaskets have a little raised edge on the inside, is that suppose to face the flange or the wastegate/turbo?
And when they say "make sure that there is 1 sealing ring on each side of the banjo hose fittings on the wastegate ports," are they referring to washers as sealing rings?
Old Dec 10, 2009 | 09:19 PM
2000BC's Avatar
2000BC
Sorry I can't help you since I had a shop install mine but if you need me to take any pictures for you I would be glad to help out. When you get it done it will be worth it. Good luck!
Old Dec 10, 2009 | 10:40 PM
american thunda's Avatar
american thunda
I wish i could help you bud but i dont have any advise. I figured it would be a easy job also.I was debating on the sts kit over a procharger system bc it seemed like it would be easier to install. I guess i was wrong
Old Dec 11, 2009 | 01:02 AM
megac5's Avatar
megac5
hey buddy jus call sts and im sure they will be willing too help u out! or if not call our local shop mayhem motorsports but im not too far from ya i live in goldsboro but would luv to help and see how she do... ima be installing my turbo kit soon once i get it fabd up
will
Old Dec 11, 2009 | 01:17 AM
bullitt4110's Avatar
bullitt4110
Yes, the washers go on each side. Kinda the same concept as a brake line banjo bolt. Its been quite some time since I did a STS so I dont remember on the gaskets.
Old Dec 12, 2009 | 03:15 PM
01QSZ06/3's Avatar
01QSZ06/3
2000BC, thank you for the gesture! I could really use some pictures of the bolts and nuts that hold the exhaust flange to the turbo. I don't see how it is possible to get the lock washer on the nut side considering 1...the pipe bends right over the bolt hole so i can barely get even the nut to screw onto the bolt let alone the lock washer too. And 2nd...the weld of the exhaust pipe onto the flange is so close to the bolt hole that if i screw down the nut it will be "hovering" above the flange instead of laying flat because of the weld. Again, thanks!!!
I'm wondering if i can grind down some of the weld to make those nuts lay flat....
Old Dec 12, 2009 | 03:17 PM
01QSZ06/3's Avatar
01QSZ06/3
thanks bullitt4110, it makes more sense to me now.
Old Dec 12, 2009 | 03:20 PM
01QSZ06/3's Avatar
01QSZ06/3
Well i don't know if i'm the only one that has had these problems or not but i would definetly like to know if i am. Like i said i have some great ideas for STS when it comes to a maintainers eye.
Old Dec 12, 2009 | 10:21 PM
2000BC's Avatar
2000BC
No problem. I'm putting my car on my lift tomorrow morning to change the oil. I'll get you pcitures and post tomorrow night. Hang in there!
Old Dec 13, 2009 | 08:35 PM
Scubanme's Avatar
Scubanme
Since I tinker with my turbos on a regular basis I can still remember what the install was like. Those gaskets that you are refering to must be the T-3 turbine housing gaskets that are rectangular in shape. I installed them with the raised bump side towards the exhaust pipe and they seem to work well like that. The raised bump is supposed to seal any imprefection so that would be on the exhaust flanged. The turbine housing is machined so it's much flatter.
The sealing rings (aluminum washers) are installed with one washer on each side of the banjo bolts.
running anything less than 8 psi is kinda worthless.
Old Dec 13, 2009 | 09:47 PM
01QSZ06/3's Avatar
01QSZ06/3
Thanks Scubanme, that's another question down. Do you happen to remember how it was attaching the turbine to the exhaust flange? Did the weld on the exhaust flange get in the way of tightening the nuts for you?
Old Dec 13, 2009 | 10:35 PM
2000BC's Avatar
2000BC
Vette's down off the lift. here's your pics. I hope they help!
Old Dec 14, 2009 | 08:13 PM
01QSZ06/3's Avatar
01QSZ06/3
Thanks, that did help. Maybe i can finally finish my project now.
Old Dec 14, 2009 | 08:33 PM
jmoody66's Avatar
jmoody66
You gonna be one happy **** when you get done. I have the STS and love the hell out of it.
To STS Self Do'ers
