Best Heads for boost?
Old Dec 15, 2009 | 01:16 PM
schnellTTZ06's Avatar
schnellTTZ06
Default Best Heads for boost?
I dont know if this has been asked already, I have searched all over and I havent found the info I need. Anyway, I would like to know what set of heads are the best for turbos. I would like to be able to run a little more boost on the stock bottom for now (currently running .5bar 7.25psi) But I do plan on building a 383 stroker with forged internals when I have time. Im not looking for a set of budget heads but dont wanna go to big either. Ultimately, the heads would have to be good enough to run 14-15 psi. I appreciate any constructive advise anyone has.
Old Dec 15, 2009 | 01:21 PM
gorillavet's Avatar
gorillavet
Whatever you get make sure they are SIX BOLT HEADS. I am running the World LS7X heads but might be a bit too large for a 383.
Old Dec 15, 2009 | 01:47 PM
glennd's Avatar
glennd
I am running AFR 225's with a D1sc at 15lbs on a 416" LS3 making 820rwhp SAE, 858rwhp actual @55F. I also made 805rwhp SAE with my 346", with the same heads
Old Dec 15, 2009 | 01:50 PM
schnellTTZ06
What do you mean six bolt heads? I am leaning towards the afr 225's. Any ideas where that would put my compression with the stock bottom?
Old Dec 15, 2009 | 01:53 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Don't worry about 6-bolt heads. You need a 6 bolt block to use them. They are reserved for rich Gorillas.
AFR's or Trick Flows will do you just fine. They have nice, thick decks. I ran 18psi on a stock casting Patriot head for 2 years and never pushed water.
Old Dec 15, 2009 | 02:08 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
The RHS Pro Elite head is also a 225cc head, with a MASSIVE .800" deck, and steel sleeves in the head bolt locations. They are known as having one of the thickest decks in the industry. They also have a .500" raised rail for shaft rockers. Their not the cheapest in the world, but they will handle 20+ psi all day long. Not to mention an excellent CNC program. The part number is 54225.
Old Dec 15, 2009 | 02:21 PM
schnellTTZ06
Thanks for all the info! Those RHS heads look great but I dont really wanna spend over 2 grand on one head.
If I get a 72cc head, does anyone know if that will allow me to run 10psi relatively safely on the stock bottom?
Old Dec 15, 2009 | 02:25 PM
black98c5's Avatar
black98c5
I'm running AFR 225's with 18psi+
Old Dec 15, 2009 | 02:28 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
Then you cant go wrong with AFR's or TFS. They both work well. Just dont gowith a large bore head. Since your staying stock bore, you need to go with a head that will work, and not be a detriment.
I "Think" AFR makes a 3.905" 225, but im not sure. But a 205 will work great as well.
Yeah, you would be fine with a 72cc head on a stock bottom end. Thats no different than running a stock 317 or 035 head. Guys do it all the time.
Old Dec 15, 2009 | 03:56 PM
MotleyDrew's Avatar
MotleyDrew
My Edlebrocks have been great and seem to make good power with such a little cam.
Old Dec 15, 2009 | 06:44 PM
95vettski's Avatar
95vettski
I'm very happy with my AFR 225's right out of the box! They seem to be holding 19-20 psi with no problems and providing some big numbers!
Old Dec 15, 2009 | 07:38 PM
Vince99FRC's Avatar
Vince99FRC
Running AFR225's here as well....
Old Dec 15, 2009 | 07:39 PM
Z06wanted's Avatar
Z06wanted
I think about any after market head will be better than factory. As for which one who knows. I know a good set of after market heads is going to set you back around 2400 plus. My ETP's were around 2900.00
Old Dec 15, 2009 | 08:33 PM
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
Blowers like exhaust flow, turbo's are the opposite. If you are on a budget, I would look into Dallas Performance ported LS3's, otherwise I would try a set of Performance Induction LS74.0's. Dallas Performance has several cars north of 1K to the wheels with LS3 heads and a Victor Jr. intake.
Old Dec 17, 2009 | 04:13 PM
Brian Tooley C5's Avatar
Brian Tooley C5
Over 1200 RWHP with TFS 245's, a hyd roller cam and out of the box Super Victor.
http://www.planetlsx.com/vehicles/Ol...or_Runs_7s/102
Old Dec 17, 2009 | 04:55 PM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
I love my TFS 235's!
Thanks's Brian!
Old Dec 17, 2009 | 05:13 PM
4DRUSH's Avatar
4DRUSH
Damn, all you guys put different heads on your car.
To Best Heads for boost?
Old Dec 18, 2009 | 02:08 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Just running LS6 Stage II heads with 77cc chambers (AFR Dual Valve Springs). Have used them with 3 different power adder setups. Made 1K hp with them no problem. Didn't pay thousands of $$ for them either...I think I spent $800 to have them done by WCCH.
Old Dec 18, 2009 | 07:32 AM
LS12NV's Avatar
LS12NV
Nothing fancy here. 6.0L truck heads worked over by WCCH. Spent under $1000. Car makes just north of 800 at the wheels...although I do get jealous when I see the dyno results of the 900 rwhp guys with their fancy AFRs...
Old Dec 18, 2009 | 03:04 PM
corvettebob1's Avatar
corvettebob1
OK I'll bite, what is the detriment to using a 4.0" bore head on a 3.905 block?
I remember GM manufacturing building big blocks that actually had the top of the cylinders notched for valve clearance.
While it may not be optimal for N/A is valve shrouding that critical for FI?
