Supercharger?
http://www.racetronix.com/product/RX-CEPH/RX-CEPH.html
If you have the Valley Cover that has the PCV nipple in the center, then this is where I suggest you hook up the line going to the Pump to evac the Crankcase Presure
I have no issues at all and it works perfect and it has a good amount of pull/Vacuum into the Air Pump
Thanks,Matt
I bought the harness for my Vette, the ugliest of them - mine is a '98 so the one on the far right is the one I needed!You will need to indentify which one your Vette has, look at the page for RACETRONIX and read over each picture to indentify which one your vette has - it is identified by the connector, unless you have my year
It certainly kept any mist coming from my Valve Cover breather and I get "NO" smell what so ever!
Do you have any evac lines going to the intake, TB, Air Inlet on the SuperCharger? What is your set-up now?
Yes it uses the stock Air Pump - usually disconnected on SuperCharged Vette's, or shall we say they are turned off!
The pupose is only on start up for around 30 seconds of run time - in order to assist the cats to heat up!
I selected the main valley cover due to the fact it is right in the middle of the motor and the pump can come on and pull additional Crank Case Pressure
Thanks,Matt
