Meth Pump Leaking
Old Dec 28, 2009 | 12:02 AM
Slow Z06's Avatar
Slow Z06
Default Meth Pump Leaking
Had the car up to change th oil today and put in the 3bar tune and sensor. Noticed the meth pump took a crap. Its leaking at the bottom where the arrow is in the picture. Is this just an o-ring or do I need to send this off to get fixed? I have also noted that I have meth pooled around the nozzle in the intake. Could this be a clogged or weak check valve?
Old Dec 28, 2009 | 12:21 AM
Chris Stewart's Avatar
Chris Stewart
Time to call Julio and he will fix you up.
Just curious, how old is the pump and what blend of meth do you run?
Old Dec 28, 2009 | 12:24 AM
Slow Z06's Avatar
Slow Z06
Not sure on the age of it. I bought it used. I run 100% M1
Old Dec 28, 2009 | 12:35 AM
Chris Stewart
Good that's what he recommends for longest life of the parts. Other additives and such can create corrosion. After talking with him, I got the impression that a few years is a good service life for this pump.
Old Dec 28, 2009 | 10:09 AM
Z06wanted's Avatar
Z06wanted
mine started doing that also. I bought a new one from him and sent my old one back to him so no downtime. Now I have a back up.
Old Dec 28, 2009 | 12:12 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Like you I got a used kit and when mine leaked I just got a new one and never have sent in the other one for repair, if this one leaks or stops working I will just put in another new one, this is an important part of my fueling and I always use 100% meth
Old Dec 28, 2009 | 12:22 PM
flash of red's Avatar
flash of red
I just had to do the same thing. Mine was leaking where the inlet brass elbow screws in. I tried to use thread seal and tephlon tape with no luck.New pump delivered right away; problem solved. Mine was about 3 years old.
Old Dec 28, 2009 | 01:34 PM
Slow Z06's Avatar
Slow Z06
GOt an email from Julio. Looks like i will just be buying a new unit.
Old Dec 28, 2009 | 03:24 PM
uniquec5's Avatar
uniquec5
Check PM>>
To Meth Pump Leaking
