weird boost gauge reading
Old Dec 30, 2009 | 09:40 AM
MYLS6's Avatar
MYLS6
Default weird boost gauge reading
I'm sitting in my car right now at idle and I'm registering 15lbs boost which I'm pretty sure in inaccurate. I have the autometer cobalt analog guage. I have been getting weird readings from it sense I returned from iraq, not sure what the deal is a couple time out the day while driving it will read correct. What can I look at as possible culprit? Car pretty much sat entire year except on couple occasions. Is the guage its self faulty or what u think? Also the afr readings really haven't been off the chart. Thanks !
Old Dec 30, 2009 | 10:10 AM
HP_Addict's Avatar
HP_Addict
since the problem is showing up in two gauges and that the car has been sitting. I would suspect a wiring issue, start by checking your grounds. Maybe you got some corrosion while sitting up.
Does that gauge use an elec sender or is it mech(ie vac line runs all the way to the gauge)
Old Dec 30, 2009 | 10:42 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Put a mechanical gauge VAC/BOOST on the line coming in the Vette and see what reading you get!
It sounds like moisture or something within the gauge is faulting - might need to send it to autometer for repair!
Thanks,Matt
Old Dec 30, 2009 | 02:03 PM
tail_lights's Avatar
tail_lights
If its mechanical (analog?) then pull the gauge out of the pod and disconnect the vacuum hose and see if it is blowing or sucking. If it reads 15lbs of boost and its sucking (vacuum) something is definitely wrong!! Or just disconnect it from the vacuum source altogether whether its mechanical or electrical and see what it reads.
To weird boost gauge reading
