Check valve
Old Dec 30, 2009 | 01:08 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
Default Check valve
How do I know if I have a check valve in? If you have any pictures showing it and were it is at that will help out HUGE..Thanks
Old Dec 30, 2009 | 02:11 PM
bullitt4110's Avatar
bullitt4110
It is usually a little clear/white plastice piece and it goes between the valley pan and the intake manifold right behind the throttle body on the pass side.
Old Dec 30, 2009 | 02:20 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
Thanks. If any pictures of it so I can install one myself. Thank you.
Old Dec 30, 2009 | 02:30 PM
Chris Stewart's Avatar
Chris Stewart
lil bit of search...
http://www.conceptualpolymer.com/PCV...eplacement.htm
Old Dec 30, 2009 | 02:59 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
Thank you. That helps huge.
Old Dec 30, 2009 | 04:58 PM
bullitt4110
I think this is what your looking for, page 18....
http://www.aacorvette.com/pdf/aa_c5_instructions.pdf
Old Dec 30, 2009 | 09:32 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
That is it... Thanks
Old Dec 31, 2009 | 12:00 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
If you don't have one let us know and we'll steer you in the right direction for one!
Make sure you don't need one in another area or line too! Rule of thumb if it can be pressurized by BOOST and it shouldn't then you need a Check-Valve
Thanks,Matt
Old Dec 31, 2009 | 03:38 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
Thanks, I know that I don't have one and need one..I think I might need two.
-One by the throttle body area
-one off of my catch can
If I am right. Thanks and if you can point me in the right direction that will help.
Old Jan 1, 2010 | 10:05 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
night bump
Old Jan 2, 2010 | 01:26 AM
bullitt4110
Mcmaster car has them on their webside, or try A&A
Old Jan 15, 2010 | 06:04 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
I just called Mcmaster car. They said the need to know the PSI and the temp it is needed for??? I had no clue..Need help. Thanks
Old Jan 16, 2010 | 12:34 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
bump
Old Jan 17, 2010 | 12:21 AM
bullitt4110
http://www.mcmaster.com/#47245k34/=5epxa2
Diaphragm Check Valves, you need the one that fits your line. An easier solution would be just call A&A and ECS and get one.
Old Jan 20, 2010 | 04:33 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
100% FIXED.Thanks
To Check valve
