I,ve got a question on 1/4 mile run,would I end in top of 3rd gear or the bottom of 4th gear,my rev limiter is at 6700 rpm,I have 390 gears and the rear wheel horsepower is 576 and 542 lbs of torque.
Ok so estimate the potential at 10.4 at 130. If that tire is about 26" tall, you should be at the top of 4th gear near the rev limit. Lots of online calculators for ET and RPM stuff. Using 26" tire and 3.90 gear shows you would likely end up in this range.
Should definitely be in 4th gear. With 507/460 and stock 3.42s I was at the bottom of 4th with a best mph of 122. I think with 3.90s you could be getting close to the top of 4th. Keep us posted
