LS2 Intake Worth It?
Old Jan 4, 2010 | 09:34 PM
Slow Z06's Avatar
Slow Z06
Default LS2 Intake Worth It?
Would it be worthwhile to switch out my LS6 intake for an LS2 intake an TB?
Old Jan 4, 2010 | 10:11 PM
mdhmi's Avatar
mdhmi
Pointless. Even if you pick up 10 HP you'll never notice it.
Old Jan 4, 2010 | 10:17 PM
Slow Z06's Avatar
Slow Z06
Thats what I was thinking but thought I would throw it out there to see what others thoughs.
Old Jan 4, 2010 | 10:34 PM
slowtealz28's Avatar
slowtealz28
ls6 intake flows better than the ls2 from my understanding.... not worth it
Old Jan 4, 2010 | 10:38 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
From my understanding and reading, the flow characteristics are very similar between the two intakes, but in a FI application, the extra 12mm opening is simply not going to make that big of a difference.
I went with the LS2 because I already had the 90mm TB and the LS2 intakes are cheap. Plenty of power has been made with the LS6
Old Jan 4, 2010 | 11:13 PM
robert miller's Avatar
robert miller
I got my ls2 from BLOWNBLUEZ06 and he ported it for me, it looked great. By what he told me the ls2 will do more for you on the top end.
Old Jan 5, 2010 | 01:25 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
While I did go to an LS2, I also uped my block size. With my previous 347, I made plenty of power with the LS6...
Old Jan 5, 2010 | 03:14 AM
dsmlights's Avatar
dsmlights
I got a ls2 manifold as well from bret(BLOWNBLUEZ06 ) I am installing it once i get back from deployment. From what I have readis 50/50 some say ls6 some say ls2. I like the fact that 90mm TB will give you a better throtle response for FI. I was going to get the ls6 with the 90MM TB but I was not sure if that would hold high boost for my future build.
Old Jan 5, 2010 | 07:28 AM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
Does anyone know the runner lengths and the plenum volume for both intakes?
Old Jan 5, 2010 | 09:09 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
In this article: http://www.vetteweb.com/tech/vemp_08...w_testing.html
They say "In forced-induction applications, the ported LS2 manifold consistently outperforms the LS6 and the popular aftermarket intakes during our test sessions," says Incaudo.
Old Jan 5, 2010 | 10:33 AM
robert miller
I like mine from you bret.
Old Jan 5, 2010 | 11:49 AM
BLOWNBLUEZ06
Old Jan 5, 2010 | 12:12 PM
tail_lights's Avatar
tail_lights
Old Jan 5, 2010 | 12:20 PM
user_name's Avatar
user_name
I'd do it if it was free. Otherwise, I don't see much value in it for FI.
Old Jan 5, 2010 | 12:28 PM
Z06wanted's Avatar
Z06wanted
I think for all out a 90mm is needed. Maybe not at 700rwh
Old Jan 5, 2010 | 03:23 PM
mdhmi's Avatar
mdhmi
... They say "In forced-induction applications, the ported LS2 manifold consistently outperforms the LS6 ...
That isn't in dispute. The question was is upgrading from an LS6 to an LS2 intake/TB worthwhile.. Given the cost I don't think so.
Old Jan 5, 2010 | 07:03 PM
Former Vendor
I'm considering this mod for next season but from what I have read the intake apparently is prone to leaking on the inside due to the friction welding process.
Apparently it doesn't make a difference with boost but I'm wondering if it affects the distribution of air in each cylinder.
I'm still leaning towards using the TPIS 90mm LS6 intake
To LS2 Intake Worth It?
Old Jan 5, 2010 | 11:20 PM
bullitt4110's Avatar
bullitt4110
Ive always wondered how that intake would hold up to boost?
Old Jan 6, 2010 | 12:17 AM
dsmlights's Avatar
dsmlights
Arun what are you using ? i was thinking about the TPIS 90MM too before but they use glue I don't know if that would hold 20psi lol.
Old Jan 6, 2010 | 06:42 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Here is a shoot-out from TPIS on all the manifolds - It is a NA shoot-out but the info is still great
http://www.tpis.com/index.php?module=2_17_06
and the TPIS Modified LS6 Intake VS LS2
http://www.tpis.com/index.php?module=4_12_06
Thanks,Matt
