SC bracket touching Damper
Old Jan 8, 2010 | 12:08 PM
huttler's Avatar
huttler
Default SC bracket touching Damper
The bottom portion my SC bracket is touching/rubbing against my ATI Damper (see pics). I tried sliding a piece of paper between the bracket and the Damper to verify they were touching. I could slide the paper most of the way between the bracket and the balancer, except for where the lip begins on the face of the Damper. I also bumped the engine over a couple times, the Damper doesn't seem to be grinding against the bracket. Its the A&A kit. Is the clearance issue I'm having normal? Any suggestions please
Old Jan 8, 2010 | 12:22 PM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
It should not be rubbing-are you sure that you have the ATI Dampner seated all the way?
If you pull out the crank bolt the crank nose should be recessed between .094-.176 into the blancer bore.
Old Jan 8, 2010 | 02:16 PM
Brandon619's Avatar
Brandon619
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
It will be close, but definetely not touching!
Old Jan 8, 2010 | 04:52 PM
tail_lights's Avatar
tail_lights
Old Jan 8, 2010 | 06:19 PM
Former Vendor
He called in and talked to one of the techs here. I think he is going to have to mill down the edge of the bracket where it's touching. The ATI balalncer must me overall wider than stock...
To SC bracket touching Damper
