custom air intake
Old Jan 17, 2010 | 07:30 PM
z06sicz's Avatar
z06sicz
Default custom air intake
Anyone do a custom air intake for their supercharger system. I was looking and it seems like it would be possible to run some plumbing across the top of the intercooler and down through the driver side side plate and mount the air filter in the driver front fender where the smog pump "used to be".
Would it be worth the extra "360 degrees" of bends for cooler air vs the warmer air being sucked by the condenser and rad
Anyone got any input??
Old Jan 17, 2010 | 08:29 PM
HP_Addict's Avatar
HP_Addict
I have the ECS Novi kit and have wondered about doing a system like the VaraRam, but with only one side. Run a duct from the fog light area right up to the supercharger inlet. Probably is more trouble than it is worth on a FI car. The SC is going to heat the air up anyway and you can run meth to cool it back down.
Old Jan 18, 2010 | 08:56 AM
z06sicz's Avatar
z06sicz
I'm thinking if the air starts cooler, it should still help keep the iat's down. I'm just no sure if the extra bending, and extended path the air must travel, will negate the benefits of cooler air. It look like it can be done with three 90's, and two 45's.
Old Jan 18, 2010 | 09:25 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
The air filter is already in front of everything and when the car is moving, I expect to be getting air as cold as can be expected from any pickup point. Also, if you ever get caught in the rain or a deep puddle, you might find yourself wishing your filter were higher.
Old Jan 18, 2010 | 06:27 PM
robert miller's Avatar
robert miller
Son had a rice burner and that happen to him. Hard to put a new rod and head on the car..
Old Jan 19, 2010 | 06:08 PM
z06sicz's Avatar
z06sicz
Hadn't thought about the rain issue:o (my car doesn't see rain), but thinking air from the front sreen would provide cooler air. Maybe your right with the car moving iat's even with the under the hood heat will stay pretty low. Dont think it would be any worse than the front air scoop they sell to replace the front lic plate cover
To custom air intake
