Electronic Boost Controller
Old Jan 26, 2010 | 10:55 AM
01QSZ06/3's Avatar
01QSZ06/3
Default Electronic Boost Controller
If you have an EBC with a STS turbo set up, where did you place the EBC and where did you route the hoses? The directions for the EBC i think are universal and don't really work for the C5.
One other thing for the pressure and return oil t-fittings. How do you keep them in place? Or do you just let them hang there?
Old Jan 26, 2010 | 12:43 PM
jmoody66's Avatar
jmoody66
Default Ebc
Are you talkin bout the little toggle switch ebc that came with the kit? If so I can take a pic of where mine was, is....it was modified into the dash but honestly I would throw that garbage away and stay with your manual setup...set it and forget it. You wont ever turn the boost down because you dont have to with that STS setup...trust me.
The oil fittings are zip tied to your undercarriage. If you havent installed it yet I would not install the return line up top in the oil cap like they designed it. The quick connect leaks and also its allot of oil to be pushing into one head like that. A much better solution is to tap the oil pan and have it return directly to the pan. Sounds hard but its not really. Its a cleaner solution otherwise pull your valve covers off and tap them, add a T and have the oil distribute more evenly across the top.
Old Jan 26, 2010 | 01:02 PM
Slow Z06's Avatar
Slow Z06
I have an EBC with a custom TT kit. Heres a pic of it.
Old Jan 26, 2010 | 03:20 PM
jmoody66's Avatar
jmoody66
Eboost 2 is def the way to go.
Old Jan 26, 2010 | 04:28 PM
01QSZ06/3's Avatar
01QSZ06/3
I was acctually talking about the selenoid i guess it is and the regulator. Apparently from the directions it's suppose to be placed next to the oil t fittings in the back. I was thinking about just sticking with a manual set up and now hearing you say that, i think that's what i'm gonna go with.
Hmmm....how bad does the quick disconnect leak?
Old Jan 26, 2010 | 06:09 PM
jmoody66's Avatar
jmoody66
Default Hard to say
Yours may not leak...whose to say but mine has from day one and its enough that it gets all over the heat shield stuff on the bottom of your hood. Its just a crappy design. I really would consider taking it right back into your oil pan or tapping the valve covers. You dont have to change valve cover gaskets so its painless and might take an hour of your day to source parts and do the work. I never could get over having that much oil shot into one side of the engine.
Old Jan 28, 2010 | 05:04 PM
eric04's Avatar
eric04
i have had my sts kit on my car for 2 years now, my quick connect doesnt leak a drop. i guess you may get lucky you may not
Old Jan 29, 2010 | 11:14 PM
jmoody66's Avatar
jmoody66
Default But
You have to agree....its a pretty cheap way to route back all that oil. I actually had one of our boardmembers tap into my valve cover and man that looked nice and was very inexpensive. I wish I had a pic of it but my new engine at the meth nozzle before I had time to even enjoy the thing and then I sold my STS.
Old Jan 30, 2010 | 02:29 AM
396375's Avatar
396375
St. Jude Donor '08-'09
You might consider race fuel when you are testing a boost controller.It will save your motor if the car over boosts.
Good luck.
Old Jan 30, 2010 | 09:57 AM
2000BC's Avatar
2000BC
I agree with just sticking with the springs and not bothering with the EBC. It's simple, mechanical, and unless your running monster boost that you want to tone down for the street you don't need it. I have the return up top (stock) and it doesn't leak, however, I also agree that it isn't the cleanest and most desireable setup but it works.
To Electronic Boost Controller
